post Flowtech LT install
gav'spurplez
07-13-2004, 01:47 AM
hey guys, i have a couple questions. first, when accelerating, i hear a ticking noise, gaskets ??
and second, when the car is at idle in reverse i hear a rattling noise that sounds like a vibration.
anyone have any info on my concerns :(
Nittanymarine
07-13-2004, 05:29 AM
My best guess as to the ticking noise, would be an exhaust leak. A leak at the flange usually sounds like that.
teke184
07-13-2004, 07:34 AM
have you re-torqued the header bolts??
i did mine about 2 times after driving for a few days.
and what kind of gasket did you use? i was warned not to use the paper one that comes with the headers...and i purchased the OEM style metal one from thunder racing along w/ the headers.
have had NO leaks
gav'spurplez
07-13-2004, 10:05 AM
just got an email from the shop. they said they used the factory gasket. does that mean GM gaskets or the ones that were on the car already ?? how hard is it to install new gaskets ?? i work at a dealer and am going to have a couple of the guys there take a look :(
teke184
07-13-2004, 01:34 PM
factory as in "GM factory" or "flowtech factory"???
the pieces that came with my headers were crappy paper pieces. i bought the OEM replacement metal ones
it's not that hard...the work is done...just remove the coil packs (provide more room) and unbolt the headers. slip the new ones in and rebolt it up.
Kataklysm
07-13-2004, 01:42 PM
I don't have flowtechs but on my headers the paper gaskets were far better then the metal ones.
gav'spurplez
07-13-2004, 02:08 PM
well the SES light came on and now one of the O2's is burnt. i think i am going with some copper gaskets. they used the Gm factory ones :(
i had read about headers being a pain, but geez :mad:
gav'spurplez
07-14-2004, 04:33 PM
went to another shop today and got the flowtech supplied bolts. the shop used the stock ones. they also used the GM gaskets. hopefully the bolts are going in tonight and it solves the problem.
teke, have you has problems with the O2's crapping out ??? how long have you had your flowtechs ?? are you happy with them ??? :alert:
teke184
07-15-2004, 07:33 AM
had em on since early April. not sure of the milage.
i've been very happy, the install was flawless, there have been no leaks to speak of and the power gain was great!
gav'spurplez
07-15-2004, 10:34 AM
does your y -pipe rest against the underside of the car ?? mine does. i am seriously thinking of taking them off and selling them. i think the shop that installed them are hacks :(
teke184
07-15-2004, 12:51 PM
my ypipe lined up PERFECTLY
on the driver side, where the indentations are for clearance, i have about 1/2" of space
i have that and more around the rest of the ypipe
i have prothane motor mounts which keep my engine movement to a VERY small minimum. so i have NO problems with the headers or pipe hitting the frame.
i guess i was a lucky one where everything slid into place with NO hassles.
gav'spurplez
07-15-2004, 01:25 PM
i have a monthly f-body gathering this weekend and i am going to talk to some of the guys and see what they think. i am going to go back and have them install new gaskets and the bolts that should have gone on there to begin with. i will ask them about the y-pipe.
birdmanz28
07-15-2004, 09:30 PM
I'm probalby goin to be buying some flowtechs jus wanting to know if theres any good info. or write ups about the install since you said you did it yourself.
gav'spurplez
07-16-2004, 12:12 AM
click on the flowtech link in his sig. his car domain page has the install write up :cool:
teke184
07-16-2004, 07:10 AM
thanks gav....yeah my write up is pretty descriptive.
and you mention bolts "that should have gone on in the first place"....i reused my stock manifold bolts for my install...:think: we'll see how they last
gav'spurplez
07-16-2004, 10:07 AM
that is odd, but you can tell that my stock bolts are not sealing properly. i got the bolts that come with the flowtechs with the locking washers :D
teke184
07-16-2004, 02:47 PM
each car is a little different...
remember, my ypipe fit absolutely perfect :think: go figure
