rocker arms
jasonss
07-12-2004, 10:43 AM
trying to find me some rocker arms, comp shows some, with 5/16 or 3/8 guides plate which one does my car have its a 2000 or does it matter
teke184
07-12-2004, 11:40 AM
look into the yella terra pieces from thunderracing...they are shaft mounted in pairs, not requireing guide plates and are about $500 i think...
i've been researching them too.
jasonss
07-12-2004, 02:00 PM
are those good rockers, do they have a good reputation
teke184
07-12-2004, 06:07 PM
i've been hearing good things about the yella terras
SSpdDmon
07-12-2004, 06:29 PM
I'm pretty sure stock is 5/16 in diameter.
mrr23
07-12-2004, 06:40 PM
5/16 is stock diameter. i use the VHP 1.89 accelerated rocker kit. http://www.vincihighperformance.com/superwebdeals.HTML
i also had them install their dual spring kit at the same time. here's the dyno results:
hp graph (http://www.stealthram.com/familypics/formula/dyno911hp.jpg)
tq graph (http://www.stealthram.com/familypics/formula/dyno911tq.jpg)
this was with no tuning. this is on the 99 formula in my sig.
teke184
07-12-2004, 09:14 PM
that's alot of freakin torque!!!
i kindda quickly added up what would be needed...and it easily tips the scales at $750 :eek:
that's alot!
mrr23
07-13-2004, 05:26 PM
sorry. but, it wasn't alot of torque. if you look at the left side of the red graph, there is a spike. that's a fluke that sometimes happens. there was a 13 lbs-ft gain. that's why i put the cursor on the graph to show the real gain.
J0HN D
07-13-2004, 05:46 PM
I like the Harland Sharps.
Greed4Speed
07-14-2004, 02:17 PM
Out of the six 10 sec LS1's in the article in GMHTP, 3 of them ran stock rockers. Save that $750 and get you a cam, headers or something that'll actually help you.
jasonss
07-15-2004, 09:03 AM
this is a heads and cam car with headers, getting rebuilt, i was gonna put some good ones in because they have problems with needles being found in the oil pan
Greed4Speed
07-15-2004, 12:58 PM
Those cars I mentioned have heads and pretty large cams. They run 10s, that should tell you someting.
AL SS590 M6
07-16-2004, 02:29 AM
I went with the Comp Cams Pro magnum 5/16" guide plate rockers, primarily because they are the cheapest way to get adjustable rockers on an LS1. I'm running Comp 'r' lifters and they are fussy about preload.
jasonss
07-18-2004, 04:07 PM
which one's would be better the 5/16 or the 3/8
AL SS590 M6
07-19-2004, 03:04 AM
You have to match your pushrods. LS1s have 5/16 pushrods.
