Timberwolf
07-11-2004, 12:21 AM
Strange Nodular Iron Case
Daytona billet pinion support
4.11 pro gears
Large pinion
3.25" bearings
Full spool
Solid pinion spacer
fully welded housing with back brace installed
1350 billet yoke
35 spline moser axles
rotors, calipers, pads all brand new
caliper mounts ready to be welded where YOU want to put them
The rear is all brand new with exactly ZERO miles on it. I actually bought it for my race car, which has been sold. It is the same width as the stock rear in the nova, only the spring perches need to be moved. I'd have to have $1500 for the rear, as it cost me over $2k and like I said, I never used it. The center section hasn't even been bolted in.
4.11 pro gears
Large pinion
3.25" bearings
Full spool
Solid pinion spacer
1350 billet yoke
