Plan to run........
Old Jul 9, 2004 | 01:36 PM
grumpy Z's Avatar
Plan to run........
I'm porting my own heads and intake, my car is stack w/exception of a buildt tranny. I plan to run an aftermarket in-tank pump and 30lb injectors w/ a 100 shot on the current stock eng., what do you nitrous guy's think?
Old Jul 9, 2004 | 02:29 PM
RacinLT1's Avatar
if you are going to run a wetkit,you really dont need the bigger injectors,unless the ported heads/new cam will require it.
Old Jul 9, 2004 | 03:42 PM
grumpy Z's Avatar
It's a wet kit. When I swap the topend I'll go with a TPiS zz9 cam, I'm told that's pretty good w/ n2o. So, to be clear, I can stick with the stock injectors, but should replace the pump?
Old Jul 9, 2004 | 05:02 PM
RacinLT1's Avatar
definately swap the pump.
Old Jul 12, 2004 | 04:50 PM
grumpy Z's Avatar
Thanks!
Old Jul 14, 2004 | 11:49 PM
DrewHMS97SS's Avatar
could do an inline pump. i recomend the racetronix kits
Formula Steve
Sep 19, 2023 08:31 AM
NewsBot
Sep 14, 2015 09:20 AM
RX Speed Works
Sep 11, 2015 03:31 PM
z28newbie
Sep 9, 2015 10:26 AM
z28newbie
