any orlando......
camzaro28
07-02-2004, 02:21 PM
anyone in orlando know how to put in a thermostat? i have had this one for about 3 weeks now and still havent got it installed! knowing that if i do it wrong my engine could overheat, i dont want to do it myself! so if anyone wants to make a few xtra bucks just reply and we can do this
MustangEater82
07-02-2004, 02:37 PM
Haynes manual is your freind...
go to a car store even a bookstore, and just pick up a haynes manual good stuff to have regardless...
most thermostats are just remove 2 bolts put it int and put 2 botls on.
Though some require removing crap to get to that spot.
anasazi
07-02-2004, 03:19 PM
yes but this is an LT1, nothing is that easy on the LT1 :)
with that being said, its not hard. some people aparently change the t-stat without draining any coolant out but i was never that adventurous because i was worried about my opti.
just drain enough out of the radiator to get it below the level of the t-stat, then put plenty of rags around the t-stat housing to protect from spillage and remove the two bolts... out comes the old one and put in your new one (make sure its not upside down).
then but the housing back on, and start bleeding the system. just open the two bleeder screws and start filling till air stops comming out (move around the hoses to get the last bit out) and screw the bleeder screws tight again. do this with the car off.
put on the air bellows, make sure the overflow is at the proper level, and turn on the car... make sure there are no leaks and your good to go. of course, check the temperature every once and awhile for the first few miles just in case but there shouldn't be any problems.
redcamaroz28
07-02-2004, 03:47 PM
To add to this, the two bolts are 10mm. Should take you tops 30 min taking your time.
Later
Crazy
camzaro28
07-02-2004, 04:37 PM
how much i would love to do this myself. i think i am goin to let someone else do it. i do not want to run the risk of getting coolant on the opti or on the other hand having my car overheat!
anasazi
07-02-2004, 04:38 PM
how many miles do you have anyways? its prolly time for a coolant flush anyways
Caps94ZODG
07-02-2004, 06:32 PM
Hey man Ill help ya!! ;)
you got a vented Opti so your some what in the clear..but better to be safe than sorry...and I got the manual too :D
just wondering ..and a flush and fill would be good to do at that time...just let me know we might be able to do it some day..or something..Im off Monday..
camzaro28
07-06-2004, 12:11 AM
yo dave(capz94odg) ur the man. thanks for the helping hand. well i guess we did it right my temp gauge stays right over the 160 mark.
to anasazi i have 47,000 miles on the car and the coolant fluch i will do in a week or two.
thank you dave again
^ ^ wouldnt take my damn money
