TheBeast_93LT1
07-02-2004, 12:52 PM
i have a 93 z-28. it has a re-built lt1 in it with only 10k miles on it. i want to go the 383 route but is to expensive to build. so, i am looking at a 3rd gen 383. what would i have to do so that i can put this motor into my car? prices? thanks.
-Daniel:bow:
zeemadman
07-06-2004, 06:13 AM
Start Slow. Prep the block. Has to be bored magnaflux etc. Buy and old 350 4 bolt main bolt. Spend money when you have it. It all cost money. If you do not prep the block, your money is wasted. A 383 is a bored 350ci. No changes, just money, need to get a stroker kit. Don...
2002Z28SSConv
07-06-2004, 08:30 AM
Most likely he's asking about fitting it into the car. He's thinking about buying an already built 383 from a 3rd gen. AKA old school small block 350. Anyone done this and retained the fuel injection? I think the biggest problem would be the distributor. It barely fits into the 3rd gen. LT1's and LS1's don't have a distributor sticking out of the back of the intake manifold. Thus no room fro one under the windshield. :(
TheBeast_93LT1
07-06-2004, 09:48 AM
how well will a lt1 383 fit in to my car? what will have to be done? prices? thanks.
-Daniel:bow:
2002Z28SSConv
07-06-2004, 11:36 AM
The fit will be identical. But you'd still be looking at all of the machining and parts to do it right.
The outside dimensions will be the same though.
TheBeast_93LT1
07-06-2004, 11:53 AM
so it should bolt right in? do i need to replace anything? i'm not using my lt1. i'm buying one already built up from a company. has warranty. does it matter if its 4 bolt? isn't my lt1 a 2 bolt? thanks.
-Daniel:bow:
