Ground Control Coil over
racinmyz28
09-24-2002, 12:02 PM
Hello all, I am setting up my GC setup on a set of Bilstein Revalved shocks. I have already installed the setup, but the collor (the red peice with threads) has slipped over the snap ring on the shocks. Is this normal.
Any help is greatly appricated. I don't wanna drive the car until I get some feed back.
Thank you all,
Kevin Hershey
94bird
09-24-2002, 09:39 PM
I hope it's normal, cuz it happened on mine. I've been using them all season with no problems.
lincmarkv
09-25-2002, 12:07 AM
Um...no...it should sit on the snap ring. That is to say, the threads go down further, but there's an indent on the inside that sits on the snap ring, if I remember correctly. I'd take it apart and check that.
Dan
94bird
09-25-2002, 04:24 PM
Dan,
That's what mine did and I bet that's what Kevin is also seeing.
racinmyz28
09-25-2002, 04:29 PM
Thanks guys for your feedback, its greatly appricated. Which side of the red collar is considered up, the smooth side or the threaded side.
Thanks,
Kevin Hershey
