ponykiller z28
06-30-2004, 12:26 AM
i have a bent axle on my 01 SS and was wondering if anyone knew where i could find a step by step guide through the install of stock replacement axles.
thanks guys
thanks guys
how to change axles on 01 SSponykiller z28 06-30-2004, 12:26 AM i have a bent axle on my 01 SS and was wondering if anyone knew where i could find a step by step guide through the install of stock replacement axles. thanks guys carlos64030 06-30-2004, 02:00 AM You would probably be better off picking up a service manual like Haynes. I personally don't know of any online instructions. Capn Pete 06-30-2004, 11:20 PM - jack rear of car up, support with stands under the axle - remove wheel from the culprit side of car, as well as brake caliper & rotor - unbolt diff cover (have oil catch pan handy) and drain oil - remove small screw holding the locking pin/block from the center of the carrier, and remove that block or pin - push the axle all the way in towards the center of the car so you can grab the C-clip - remove the C-clip, then remove the axle - voila!:D the axle is out! - reverse steps to re-install:thumb: | ||
