1982z28with18s 06-29-2004, 02:15 AM I should be right at 400rwhp n/a with my heads/cam setup. See sig for details. I'm looking at high 11.3x's on motor here soon so how much do you think I could spray? I'm thinking a 75 shot just to get in the 10's. I'm a little more worried than the average person since I already have 400rwhp. Any ideas?
QCKZ28 06-29-2004, 03:44 AM i plan to spray 150NX on my heads/cam car in sig later this summer :)
i will let you know what breaks :D
jesse
1982z28with18s 06-29-2004, 03:48 AM Originally posted by QCKZ28
jesse
K, probably will be a rod. ;)
QCKZ28 06-29-2004, 03:53 AM Originally posted by 1982z28with18s
if the rear end doesnt go out 1st :)
i plan to have a window switch from 3000-6000 rpm
100 octane, and i will dyno it on the spray to make sure the a/f is correct....
i dont plan to spray until 2nd gear....
DrewHMS97SS 07-02-2004, 12:02 AM shoot a 100 shot. just be really carful with the fuel jetting. new fuel pump and all is a must for safty.
slomarao 07-06-2004, 12:37 PM C16 gas. Or the highest thing you can find. You should be ok with a 75. People spray more and get away with it. I would do it on a dyno first and pull more timing. But hitting the juice out of the hole will help your 60ft. big time.
1982z28with18s 07-08-2004, 01:54 AM TTT... I'd like to go high 10's on stock bottem end, 10bolt, and 4l60e.
HungryT/A 07-08-2004, 04:36 AM Maybe Derrick can chime in here. He sprays a 175 shot on a Heads/Cam Z with completely stock shortblock.
Z-RATED94 07-08-2004, 12:04 PM Derrick does, or did?
RacinLT1 07-08-2004, 01:06 PM Derrick does,still has the 10 bolt in his car also.
I sprayed 175 pon a stock longblock and went 11.02,woulda gone 10's but the output shaft of the 4l60e didnt agree and broke about 50' off the line.
COMNBYU 07-08-2004, 06:40 PM Werd. There are a lot of guys still running stock sb with n2o. I would say you'd be fine with a 150 or so.
Also, you're NOT going to get into the 10s w/ a 75 shot. Moreover, with 400 on tap NA, you won't even feel the 75 more than likely...
Jon
DrewHMS97SS 07-08-2004, 09:52 PM he would def feel a 75 shot. 400 is a lot out of a stock setup. i dont think i would push 150. maybe if he had done rod bolts.
1982z28with18s 07-09-2004, 12:50 AM Originally posted by COMNBYU
Jon
You don't think a 75 shot would net me 10's? I'm planning on running low 11.3x's on motor.
DrewHMS97SS 07-09-2004, 12:53 AM most ppl i have heard of drop about a second on a 100. so yes 75 shoud do a 10 if you are 11.3 on motor
1982z28with18s 07-09-2004, 01:00 AM Originally posted by DrewHMS97SS
It better get me 10's. :D I don't see me having a problem hitting 11.3x on motor with decent weather and the little mods I have coming up.
DrewHMS97SS 07-09-2004, 01:14 AM u should get a fpr bro
DrewHMS97SS 07-09-2004, 01:16 AM oh yeah, since i always forget to send pics, check out the webshots site :)
1982z28with18s 07-09-2004, 01:18 AM Originally posted by DrewHMS97SS
Looks like its coming along good. Hit me up on aim sometime, I'm not on late anymore though(usually).
DrewHMS97SS 07-09-2004, 01:29 AM i reinstalled not too long ago. i dont think i have it installed again yet. let me go jump on
Derrick Redd 07-09-2004, 05:44 AM The 76k mile stock shortblock is still together. :D I haven't been to the track in awhile with the car. Been busy with other projects. Still having some fun on the street though. ;) I'm contemplating going with a 28" tire and upping the rear gear. I ran the 11.03 with 17" wheels in the front and traction issues. I wish the skinnies I now have were on for that pass. Would have been the 10.9x I'm looking for. I still don't have a cage. LOL. But No Problem has Midnight Madness every now and then. :thumb: Can't wait for the cool weather. :cool:
1982z28with18s 07-09-2004, 06:16 AM Originally posted by Derrick Redd
You got any dyno #'s and what do you run on motor?
Derrick Redd 07-09-2004, 06:24 AM I ran a best so far of 12.09 @ 112.21. That was with 17's up front too. LOL. ;) 3650 raceweight. And the 3.42's are killing me NA.
COMNBYU 07-09-2004, 10:29 AM Originally posted by 1982z28with18s
No I don't. Not trying to sound like a dick, but as you build up a car making a lot of hp NA, n2o is not going to pick you up like it would on a stock car.
For EX- my '96 w/ cai & exhaust typically went 13.8s @ 100 NA. With a 150 shot it went consistant 12.0s @ 115. That's a lot for a 150 shot, but the car was bsically stock at the time. I've got a friend of mine w/ a '81 Malibu that runs 10.8s NA. On a 125 hit went a best of 10.3. Not exactly what you would expect, huh?
That's just the way it works. Once you hit the low 11/high 10 sec mark, it's going to take more nitrous to make you drop the same ET that say, a stock car would drop.
I'm sure you're going to have a hard time swallowing this but oh well. I know from experience. Here's my guess as to what you'd run with different jetting if you run...lets say, a 11.35-
75 shot- 11.0s, maybe 10.9s
100 shot- 10.6-.7s
125 shot- 10.5s
150 shot- 10.2-.3s
175 shot- high 9s
JMO from the eperience I've had...
Jon
