lethalz
06-28-2004, 12:40 PM
I'm planning to spray 150 shot, and i'm not sure if, do i have to increase the fuel pressure?, I got an adjustable fuel pressure regulator from aeromotive to replace the stock, but I can't adjust it, the pressure remains at 60 psi. any info?
thanks in advance
P.D. I have learned a lot of tips in this forum, thanks to everyone
Injuneer
06-28-2004, 01:41 PM
What you need to do with the fuel pressure depends on what type of system you are running - wet or dry? If wet, what kind of device are you using - TB plate, nozzle of some sort, direct port? If dry, which kit?
There is an "N2O Tech" forum for questions like this.
1984camaroz28
06-28-2004, 01:51 PM
more info on the kit u bought or plan on buying
lethalz
06-28-2004, 02:23 PM
Is the Nitrous Works wet kit, and i still can't adjust the fuel pressure, i don't know what i'm doing wrong.
rskrause
06-28-2004, 03:20 PM
Generally speaking there would be no need to adjust FP when running a wet nitrous system. The correct nitrous:fuel ratio is achieved by changing jet sizes. What exactly are you trying to accomplish?
Rich Krause
1racerdude
06-28-2004, 03:31 PM
60PSI is probably the max limit for your pump.Set it back to stock,I think around 45PSI and see.The pump won't last long running at max.The NO system will put the fuel there if you have the right jet and it is installed correctly.Most people install a 255 or larger pump when running NO,just for insurance.
lethalz
06-28-2004, 05:22 PM
At WOT the fuel pressure drops to 38 psi, and I though with replacing the stock FPR, and set it to higher pressure (45-48 psi) ensure a good combustion, but the new FPR can't be adjusted or may be the procedure is not correct, because even adjusting the knob the pressure remains at 60 psi
1racerdude
06-28-2004, 05:38 PM
Sounds like a pump GONE WILD.The reg should adjust to whatever.Got me without being there to see it.Are you SURE you have the reg installed correctly?
Injuneer
06-30-2004, 12:57 AM
Do a "search" on the Aeromotive AFPR.... virtually every post I see here on that regulator is from someone who has one that doesn't work. They seem to work just like yours..... not at all. Appears to be a poor quality product.
