Nitrous is the thing for me I believe.
99_Z_155
06-27-2004, 08:50 PM
I have decided to get nitrous. It is for me because i am a poor college guy. I do however have the normal array of questions from you guys, and i hope to have them answered.
I know some stuff about nitrous and some about the installation, because i have been doing some research here on the board and elsewhere.
Here are my questions:
1. What is the cheapest setup that comes with the goodies needed to make everything work like silenoids, WOT switch and what not?
2. I dont know how much of a shot i would like to use but im thinking 75 to 100. My car is very close to stock, so i dont know what it can or cant handle.
3. I read things here on the board about guys having over 100 shot and having a timing retard issue of some sort. If i have this problem, how is it corrected? Is it cheap to take care of?
4. I see this site called Jimmy Jam's i believe has some cool custom switch plate type stuff. Are there other sites with such things?
5. Finally, i think i would like to do a stealth type installation, it will have to be in the spare wheel well. Where is the best place to run the fuel lines, and will there be enough line?
Im a smart kid, and have done several hands on type stuff on my car, and i think i can do this install with some time.
I very much appreciate the help that you guys give me. I do hope to have answers to these questions so i can get going on having some FUN!
Thanks Guys (and gals i suppose)
RacinLT1
06-27-2004, 10:27 PM
the basic kits comes with solenoids,enough line from bottle in spare well to engine,full throttle switch,arming toggle.
really dont need a retard for a 100 shot if you use nx.
100 is fine for a stocker.
jimmy jams makes the custom full throttle switch bracket,only 1 like it i have seen,but there are hundreds of sites with accesories.
i ran the nitrous feed line under the carpet through the firewall.
96birdlt1
06-27-2004, 11:00 PM
Welcome to the darkside young padawan.
A 150 shot is fine on a stock engine as well. I've been running that for years with no problems.
Get a MSD ignition box with timing retard and colder plugs as well.
Good Luck
Joe
99_Z_155
06-28-2004, 01:27 PM
thanks guys. 96birdlt1, how much was your kit and msd and everything as far as cost alltogether. was it under 400 or 450? Is it also safe to run a 200 shot like that also if you have the timing retard? A friend of mine said i also needed an msd box that controls the sparks at certain rpms for safety? Thanks again guys, more input would be great.
mikey9495
06-28-2004, 02:55 PM
99_Z_155,
I sent you a PM. Feel free to write!
mrr23
06-28-2004, 07:27 PM
just ran a 200 shot on my 00 formula on father's day. went 11.97 @ 118 all stock except for SLP airlid with filter removed. went 13.60 @ 102 all motor first run of the day.
2000 formula (http://www.stealthram.com/2000pontiacformula.html)
slomarao
06-28-2004, 09:50 PM
The LS1's shortblock is stronger than the LT1's, people have pushed the limits way farther than with an LT1. But is 200 shot is going to be a risk any way you cut it. I am in the same spot as you- broke college kit who want to go real fast. A dual stage or a progressive controller would help engine life at that amount of nitrous. Hope you have the money for a rebuild in case of a bad day with a juice. But if that happens than you just build it stronger and go with bigger jets.
mrr23
06-28-2004, 09:55 PM
i did what i wanted. 11s all stock. now i'll start adding hard parts and back off the n2o.
96birdlt1
06-29-2004, 03:57 AM
My kit alone was around $500. A MSD and harness look at spending another $200 or so , if you buy brand new. Look at the parts for sale section. I've gotten alot of great deals there.
Oh, by the way, I know better now, but I did not have a MSD ignition and retard the timing for the first 2 years running a 150 shot. I didn't have any problems, but every engine is different. Don't do like I did. Play it safe.
Joe
