Extremely quick A4 question...(need answer today)
texasTA
06-27-2004, 11:41 AM
I have everything out except for the actual tranny (doing it this afternoon with daylight). My quick question is:
Do you have to take the shifter handle off when lowering down an a4 transmission?
I have an extremely good write up on installing a stall convertor and they never mention whether or not you have to remove the handle. Now common sense tells me that more than likely it needs to be removed, but I don't want to do any more work than I need to.
Thanks, and if it matters I am taking this tranny out and swapping it into my brother's camaro. I am getting his fully built a4, since he is selling his camaro.
flyinZ
06-27-2004, 11:46 AM
If you talking about the actual handle in the console, Im going to say no, it doesn't have to be removed...There has to be a way that it disconnects from the tranny, like the shifter linkage or something of that nature..
texasTA
06-27-2004, 12:17 PM
Oh, doh. You have to unbolt the shifting linkage from the driver's side of the tranny. Thank you.
Capn Pete
06-27-2004, 01:13 PM
An automatic shifter is bolted to the floor of the car;). It's not like a standard where the shifter is bolted to the tranny and pokes up through the floor into the car:no:. There's just a cable coming from the auto shifter that connects onto the driver's side of the tranny:thumb:.
robvas
06-28-2004, 09:23 AM
I had to take my console apart, because my cable binded up. But like stated above, it's not like removing a 5 speed where the shifter is part of the tranny.
