Wishmaster
06-26-2004, 03:36 PM
I posted this on the other boards also, I want to get as many opiions as I can to figure this out...
I was checking things over cause Ive been hearing and feeling a bad clunking noise when putting into gear and going from reverse to drive.
I raised the rearend and started the car and put it into gear, my passenger tire spins under load but my drivers tires doesnt not until a give it some gas. I can alomost hold it from turning, Is that because of the SLP torsen Posi unit? normal?
I was checking to see if my U-joints were bad but found them to be tight. I guess?
Now, I had my wife sit in the car and put it in neutral, the tires still spun and the driveshaft was still turning, I had her apply the brakes and it stoped but when she released the brakes the driveshaft started spining again and the car was in neutral.
I then had here go from neutral to reverse to neutral to drive and kept doing it while I was under the car looking at the tranny motor mount to see if it was moving under this slight load, that was OK but the tranny made a terrrible clunking sound when going thru the sequence I had her do. whats wrong? Tranny going out? slipping bad?
The other day when I was in traffic and just started to move ther was a noise under the car aswell...Im pretty sure its not my rearend ....
whatcha guys think? whats wrong?
tranny fluid is ok....
