YARDofSTUF 06-25-2004, 01:07 PM Whole engine
http://www.imagemagician.org/images/yardofstuf/DSC00011.JPG
Left side
http://www.imagemagician.org/images/yardofstuf/DSC00012.JPG
Right side
http://www.imagemagician.org/images/yardofstuf/DSC00013.JPG
Front
http://www.imagemagician.org/images/yardofstuf/DSC00014.JPG
:cry: It looks so ugly now!
Pneumatic_Tire 06-25-2004, 01:41 PM 305 v8. To be sure you can read the 8th digit of the vin number, and tell us it. That will be the identification for the engine type.
YARDofSTUF 06-25-2004, 01:52 PM E9K, one of those, dunno if the first thing is a 1 or not counted or whatever.
I was told this is not the original enigine and that a V6 was there.
What kind of potential do I have with a 305?
virtualdemo 06-25-2004, 02:29 PM Looks like a TBI L03... But if they swapped it out it could potentially be an L05, wont be able to tell till ou get block/head #s. But it looks like the original engine... Little things like the heater valve, brake booster lines, Map sensor placement... All looks original to me... Dunno but besides the rust, looks exactly like my Engine used to be....lol
Lates,
Demo:bow:
YARDofSTUF 06-25-2004, 02:55 PM Is it usable? Also is there room for a 350 in there?
IROC-T 06-25-2004, 03:44 PM By the looks of it I would say an LO3 out of a submarine or a mud bogger ,was it in a flood? Like virtualdemo says need more #'s to be sure. Man that is nasty!
YARDofSTUF 06-25-2004, 04:05 PM Man, my baby has been given so much s***, we had a water leak from one of the pipes in the garage, right over the engine, plus a coolant and tranny leak that may have added to it?
Should I be looking into a new engine? would a 350 fit?
I just wanna drive this thing again!!!
Pneumatic_Tire 06-25-2004, 04:32 PM Yes a 350 would fit, its the same block size as a 305.
YARDofSTUF 06-25-2004, 04:35 PM Originally posted by Pneumatic_Tire
ok, cool.
Is this one still good and usable after removing the rust? is it worth that kind of time?
virtualdemo 06-25-2004, 05:12 PM Looks usable. How does it run? I would replace that poor alternator, might have rusted bushings inside. Also might replace the belt tensioner, dont look too promising there. And from the looks of things, I would check the A.I.R pump as well, or in my case remove it... I wouldnt worry too much about the rust... Its just on the surface of the pulleys, just make sure to check em out good. Replace the belt and check for slack... Trust me I have seen way worse...lol What kind of car is it? Maro or Bird? Im curious now...lol
Lates,
Demo:bow:
YARDofSTUF 06-25-2004, 05:30 PM Firebird
Ok I know what the alternator is, rest, ummm ya... :)
belt tensioner? AIR pump? Remove it?
As far as how does it run, heh. Right now it doesn't. Tanny is toast, was gonan have it rebuilt but in the gen tech forum someone mentioned that having one rebuilt is more money than buying a good condition used one and looked around and he was right.
I got an estimate of 900-1100 to have the tranny rebuilt, seen 700R4s used for about 350-450 bucks.
Now I keep reading this forum and am getting interested in this 4.10 or 4.11 gear thing. So who knows whats gonna happen with that.
Back to the engine, it ran great before the rust. when I find the stupid key and bulk order some transmission fluid I could play with starting it up.
As far as removing things, hey i'm open to whatever you guys suggest!
Alternator wise are used ones good to go with, I know the price difference at pep boys is pretty big.
YARDofSTUF 06-25-2004, 06:03 PM Ok I dug out my Chilton's 82-94 Firebird Repair book.
Air Injectio Reaction system, gotcha! :)
virtualdemo 06-25-2004, 06:49 PM Originally posted by YARDofSTUF
Firebird
I dont know the particulars of your states emissions so I wont suggest removing anything. I live in New Mexico and as long as your car isnt stincking up the road they pretty much let you have your way. But I did notice an A/C delete pulley. I would pull off the condensor if its still there. The car would cool better too...
You could go with a used alternator but why? You just risk having your electrical system fried or keep replacing batteries. Dont go cheap, I learned the hard way...lol If your car is computer controlled and you have no experience with it....go with new.... well at least I would..
Lates,
Demo:bow:
P.S. Dont worry about new engines till you check yours out;) unless you want an "excuse" to....lmao:cool:
YARDofSTUF 06-25-2004, 07:24 PM Originally posted by virtualdemo
LOL, The number 350 sounds so nice! :D
The problem of putting a 350 in there for me would be finding a place that would install it.
whats the difference in HP and torque between a stock 305 and a stock 350?
YARDofSTUF 06-25-2004, 07:27 PM oh and by used alternator i meant a rebuilt alternator, u have the same opinion still?
YARDofSTUF 06-26-2004, 03:54 PM So what are the recomended items/tools/spays/pastes or whatever to get the rust off?
IROC-T 06-26-2004, 05:35 PM Would start at the car wash if it drives ,then use some kind of degreaser/engine cleaner(walmart sells a driveway cleaner REVIVE that works well for this) ,a couple of small wire brushes,maybe a good parts cleaner brush ,and some rust-o-leom paint to start,don't worry to much about the pullies that will wear right off as it runs a little ,after clean-up you may want to sray some lube on the moving parts like the tensioner,wipe all your hoses down with a rubber conditioner(replace any that are soft/cracked,etc.),mask and paint parts that show and that you can get to easily(don't just spray everything )take your time and mask things off before. You'll have it looking clean and that will be a big improvement over what you have now. A little elbow grease goes along ways. Good luck. :)
YARDofSTUF 06-26-2004, 05:48 PM Originally posted by IROC-T
Awesome, I'll start at the degreaser part since it doesnt run, should I be using protective gloves, goggles and some sort of mask for any of these chemicals?
You guys rock! :metal:
IROC-T 06-26-2004, 05:52 PM Safty glasses or goggles wouldn't hurt ,if you use the stuff i mentioned you don't need any gloves ,and it is biodegradable. so it won't hurt the lawn if you get any on it.
virtualdemo 06-26-2004, 08:24 PM Rebuilt is just as good as new. I thought you were gonna go with a junkyard piece...lol
The 305 vs 350 hp...
I believe in stock form you get at least 30hp more out of a 350, plus your upgrades will benefit more from the 350. The only problem with swapping to a 350 is the compter. You have to get the Knock sensor, Ingition control, and computer to do the swap. Or you could go with an aftermarket for some $$$. Just do a search on it because I have seen it on many sites including this one. For some reason we love to talk about HP and Torque...haha :D
I noticed you mention gears....woooohooooo 4.10s Baby!!! Thats my plan too, along with the posi unit....:D
Lates,
Demo:bow:
