Nitro Dave
06-25-2004, 12:00 AM
Hey guys I have been checking this board out.Im just wondering how many nitrous guys we have here and what type of systems are you running? Dont be Shy,Post up.
Dave
Dave
How Many Nitrous Guys Are Here?Nitro Dave 06-25-2004, 12:00 AM Hey guys I have been checking this board out.Im just wondering how many nitrous guys we have here and what type of systems are you running? Dont be Shy,Post up. Thanks Dave LSUxBlake 06-25-2004, 12:05 AM Nitrous Works GM EFI 150 shot. 96birdlt1 06-25-2004, 12:28 AM NX wet system 150 shot. I am thinking of getting the NOS throttle body though. Joe rskrause 06-25-2004, 06:09 AM Custom twin nozzle system using NX components, good to 300hp though I never sprayed that much since I also use 20psi of boost! Rich Krause Nostang 96z 06-25-2004, 06:39 AM Running NX S.H.O. kit @ 150 hp. This kit is supposed to be good up to 400 hp but I am not going to be the guinae pig to try it out. Matt 96speed 06-25-2004, 08:01 AM Hybrid system with NX solenoids/nozzle. Haven't sprayed yet. Looking to start at ~100 and stop at 200 (forged pistons) :D. Ryan LT4383 06-25-2004, 11:55 AM NX Gemini kit 180 shot. Injuneer 06-25-2004, 11:57 AM 300 dry shot, made out of a lot of parts from my old NOS 5176 kit, and controlled along with the rest ofthe engine by a MoTeC M48Pro ECU. Only sprayed the 300-shot on the dyno. Haven't run more than a 125-shot at the track. Soon :D LT4ultraZ 06-25-2004, 02:07 PM twin nozzle NX system set at 100. speedmiser 06-25-2004, 02:42 PM Until recently, a Dual stage 300 wet shot w/ 2 NX nozzles and a mix of Compucar, NOS, TNT, & Parker parts. Bought an S-trim not to long ago, so the nitrous is going to be scaled back considerably. a walker 06-25-2004, 06:31 PM Nitrous Works LT1 wet plate kit. It's jetted for 175 hp, although on the dyno I'm only getting 113 hp at the crank from it :( ford 06-25-2004, 07:14 PM I just joined the bandwagon with a NX Gen II kit :p probably will run a 125 shot till i can piece together a forged 355 :D ltwonz 06-25-2004, 07:18 PM nitrous works power wing kit/ 125 shot darkangel95 06-25-2004, 10:25 PM I am running a TNT F1 kit, but soon plan on going to either a MX MAF dual stage, TNT F2 or a direct port system of some time. Nice to see you over here Dave, when I order my next Nitrous setup it will be from you. I have heard nothing but good things about your service. silverz28 06-25-2004, 10:46 PM I'm still doing the install on my NX GM EFI kit. blksunshine 06-26-2004, 07:19 PM Nx Kit 150 With a carbon fiber bottle:D 7.6's on motor 7.1's 96mph with a 100 7.0's 99mph with a 150 I couldnt hook:( the 175 and 200 wont go in until I get this think to hook! MEAN_SBC 06-26-2004, 11:00 PM NX Gemini Quad Plate system good to 800 shot... Dedicated fuel system with 1 gallon Jaz fuel cell, Mallory Comp 250 fuel pump, dual regulators, fpss, and MSD window switch... BILLJ 06-27-2004, 11:13 AM Fully hidden dry kit. 135ish RacinLT1 06-27-2004, 11:39 AM was running a NX single nozzle kit,maximizer,175 shot. 11.02@124 with a stock longblock. Sold my nitrous kit,but still tune them for friends. quick-z 06-27-2004, 12:30 PM I just installed my NX wet kit with a 100 shot. I still haven't been to the track yet, but hopefully will soon. SDAKOVIC 06-27-2004, 02:25 PM All you need to know is in my sig below.:bow: FLYNLOW92rs 06-29-2004, 07:32 PM NX 75-150 shot (wet kit) HungryT/A 06-30-2004, 05:42 AM cheap NOS #5115 dry kit, sprayed 125 shot last year. hambone3441 06-30-2004, 07:42 AM Nitrous Wet kit here 30thCamaroZ 06-30-2004, 12:37 PM Compucar plate kit using NOS cheater solenoids. and a nozzle kit using the new Nytrex nozzle and NOS powershot solenoids. I could easily spray 400 through this if I want but I am going to go direct port on the new motor. GJE94Z28 06-30-2004, 10:08 PM NX wet kit, 100shot. BBCAM 07-01-2004, 12:59 AM IM, running a 78Z with a 408 BBC, had a 350HP 10.000 rpm plate .. ran 11s now has a NOS/custom fogger 500+ HP FRESH ENGINE AND NO runs yet.. should be fun if it hooks :D just redid the whole car so its still being broke in... 1994CamaroZ28 07-01-2004, 09:38 AM TnT F2 main kit, NX genx2 upgrade digital 6+ ignition :p Derrick Redd 07-01-2004, 01:39 PM NX wet 175 shot. Currently with a single shark nozzle, possibly going with an dual stage and SX2 nozzle. JJJ93z 07-01-2004, 06:07 PM NOS bottle , and lines, NOS & NX solenoids, NX nozzle. 150 shot Rich_z28 07-01-2004, 08:09 PM I've got a NX 150 shot wet kit. n2oCamaro 07-05-2004, 03:29 PM Ran a Nitrous Works wet kit on my stock motor. Going to a NOS sportman fogger (200 shot) on the stroker. JJJ93z 07-05-2004, 09:10 PM n20 camaro. are you doing the work on your motor yourself? i was wondering about how much it would be for a 383 stroker with lloyd elliots and custom cam? also what internals are your going with ? n2oCamaro 07-05-2004, 09:23 PM Originally posted by JJJ93z n20 camaro. are you doing the work on your motor yourself? i was wondering about how much it would be for a 383 stroker with lloyd elliots and custom cam? also what internals are your going with ? Motor was built by Launch 1 Motorworks here in Southern IN. Its all forged, Scat crank and rods, JE pistons, splayed caps. I have 5k in the motor itself. JJJ93z 07-05-2004, 09:24 PM Originally posted by n2oCamaro Motor was built by Launch 1 Motorworks here in Southern IN. Its all forged, Scat crank and rods, JE pistons, splayed caps. I have 5k in the motor itself. what kind of trans and rear are you going to run? also what kind of numbers do u expect to be looking at? n2oCamaro 07-05-2004, 09:33 PM Originally posted by JJJ93z what kind of trans and rear are you going to run? also what kind of numbers do u expect to be looking at? I will have a rebuilt 4L60E w/ Yank 3200 stall and 12 bolt rear. I hope to have 400+ rwhp N/A and 600 on the bottle. This motor was built specifically for nitrous. More on it here w/ pics: http://web.camaross.com/forums/showthread.php?s=&threadid=278992 JJJ93z 07-05-2004, 09:37 PM Originally posted by n2oCamaro I will have a rebuilt 4L60E w/ Yank 3200 stall and 12 bolt rear. I hope to have 400+ rwhp N/A and 600 on the bottle. This motor was built specifically for nitrous. More on it here w/ pics: http://web.camaross.com/forums/showthread.php?s=&threadid=278992 thats beautiful! so where are the sportsman fogger nozzles on that motor? the fogger is not direct port right?(not sure) n2oCamaro 07-05-2004, 09:41 PM Originally posted by JJJ93z thats beautiful! so where are the sportsman fogger nozzles on that motor? the fogger is not direct port right?(not sure) I haven't got the NOS kit yet. Yes, it is direct port. It will go on after I get the motor broke in and get some more $$. I just want to get the thing in and running for now. JJJ93z 07-05-2004, 10:12 PM Originally posted by n2oCamaro I haven't got the NOS kit yet. Yes, it is direct port. It will go on after I get the motor broke in and get some more $$. I just want to get the thing in and running for now. well when you put it in and get her goin could you drop me an email and let me know how its working for ya? email JJJman0215@aol.com thanks MetallicTrans96 07-06-2004, 01:07 PM NOS bottle, Nitorus Works Plate system 75-175 chevy1963 07-06-2004, 04:29 PM I have an adjustable wet shot. I'm running 150 shot. 383Z4ME 07-07-2004, 02:46 PM I bought the NOS Noszles wet direct port universal kit for my LT1 383. I am having the fuel sytem installed right now. The NOS system is good to 300hp and I plan to step up to that eventually. I am replacing the fuel tank with a 8gal Jaz cell and using a Aeromotive A1000 pump running 10AN braided line to a 'T' up front with dual Aeromotive regulators. Rick n20ta2 07-07-2004, 11:15 PM Was running NW wet kit just installed a home made system consisting of nos 250 hp cheater celonoids and two fogger nozzles called nos for the jetting. | ||
