Where did you mount your Auto Meter shift light?
lons94z
06-24-2004, 07:41 PM
Wondering if there is some place that works best?
Bud M
06-28-2004, 12:21 AM
I put my shift light at the base of the A pillar
ianwells100
06-28-2004, 01:16 AM
for a 97+, which i have, i got mine in one of the air vents, works perfectly, and is stealth
94BlackBowtie
06-28-2004, 02:17 PM
I mounted mine right beside my automatic shifter. :o
:D Just kidding. I was going to suggest the air vents.
Brandon 95 Z28
06-28-2004, 04:15 PM
Mine is to the right of the steering wheel, near the ac vent. Here are some pics:
http://www.u.arizona.edu/~mbb/car_pics.html
Brandon
12SCNDZ
07-01-2004, 11:06 PM
Here.
http://www.geocities.com/max_wylde/interior.jpg
Frank
ianwells100
07-02-2004, 12:54 AM
;) look at the above posted pic ;)
lons94z
07-02-2004, 07:13 AM
OK a couple more questions
Red wire is pretty simple. Just go to the fuse block.
Where did you connect the green wire? I have heard that the pink/black wire going to the coil will give a tach signal.
And a simple wire....the ground. Where did you connect this? I would like to find SOME metal in or under the dash, clean it off, and attach the ground.
When I installed the scanmaster earlier this year I couldn't find any metal, and just ran it's ground to my fan switch's ground. (which runs right to the ground at the battery. Problem is I think this is the reason I keep getting a fan relay code. So I have to find some metal for both the shift light and the scanmaster.
Thanks for any help.
12SCNDZ
07-02-2004, 07:22 AM
I got a wiring diagram for my car and tapped into the wire running to the factory tach, in the instrument cluster. I grounded it to one of the bolts coming through the firwall near the steering column.
Frank
