Where to put an open air filter?
firebirdjosh
06-23-2004, 04:11 PM
I am redoing my whole intake and the only thing left to do is mount the filter. Where should I mount it? The stock space or maybe straight down in front of the serpentine belt right above the sway bar? I have a V6 so there is alot of room to mount it. Thanks./
virtualdemo
06-23-2004, 04:18 PM
Put it where it can get the coolest, cleanest air. Make sure to run the ducting away from heat too...
Lates,
Demo:bow:
firebirdjosh
06-23-2004, 07:51 PM
So would going straight down be a good idea? Or is it cooler by the stock location?
Lungz
06-24-2004, 09:32 AM
I would say straight down behind the radiator is NOT a good idea. This location tends to get less airflow than other locations, I would say if you run it straightdown in front of the radiator would be more ideal. Try to optimize clean, cool, and flow.
