1badasZ
06-22-2004, 07:05 PM
do nitrous cams still run pretty good on motor? n also what is different about them from regular cams? and if i run one of those and some of the ngk 4 degrees colder plugs and upgrade the fuel system can i spray a 175-200 shot? also i have tuner cat so i can retard timing :D
SDAKOVIC
06-22-2004, 07:49 PM
No, and you can run a 175 shot if you back a little timing off and go maybe 1 or 2 plugs colder and try to run at least 92 or 93. I would back timing off with an MSD and your going to need at least an in-line fuel pump to back up your in tank pump. I have been doing it for a long time with no problems and I even have a blower with 6.0 p.s.i. :cool:
slomarao
06-23-2004, 08:21 PM
If you want something for all out nitrous use it wouldn't give you the best N/A gains, not too hard of a concept to grasp. But if you want to just make sure that nitrous doesn't go to waste get your cam on 114lsa. A 175 shot would work good with a 224/236, but the cam is not going to allow you to run more nitrous safely or anything.
