billsbird
06-18-2004, 02:07 AM
....yeah, I also put my new Suspension Technologies sway bar on the other day {35 mm. solid, I believe?}. Anyway, its as if my car is super glued to the ground!!! An AMAZING difference!!! For those of you who are putting it off? Do it!!! You'll never regret it...... Bill
Highlander
06-18-2004, 03:53 AM
I went up from the 29 to to the 32mm 1le...
I haven't tested much... but there should be some difference.
Red96Lt1
06-18-2004, 11:30 AM
Not trying to knock on you, but I went with BMR because they said that their sway bar is 40% siffer than the 1le. I'm sure you should be able to tell some difference though.
Highlander
06-18-2004, 01:48 PM
It should be stiffer... but if GM decided 32mm was enough for our cars.. then that is what i chose.. besides.. too much sway bar can cause understeer and when you live in a place with lots of patholes...well... you get the idea ;)
