I think my next project four my fourth gen is to cut the front end off at the fire wall and build a tubular front chassis. with the twin turbo set up and the superram intake with hei Distributor i am out of room and it would be so much easier to work on with the front end and fenders pinned for easy removal. does anyone know of anyone that has done this?
mongse_1
06-17-2004, 05:07 PM
I've got BMR tubular k-member and a-arms on my twin turbo car and it's pretty easy to run everything. Not sure how much more room you'd need. :confused:
I also have the bmr k-member but wouldn't it be nice to be able to just lift the bumper and fenders off and out of the way and also lose a couple hundred pounds . maybe I'm just getting old and lazy. room also depends on how your turbos are plumbed and how large the turbos are. I'm running twin turbonetics t60 P- trim turbos with 31/2" and 4 " tubing, evolution waste gates and a godzilla blow off valve.
Xride
06-21-2004, 01:44 PM
its possible, but 100% custom, and I dont think anyone has done this.
If your good at fab work go and buy some tubing and then go at it.
But take lots of pics as you go along, will be interesting to see how it turns out.
