Alternator question
ead94z28
06-13-2004, 04:15 AM
Charging amps are 12.5. I know they should be in the 14.5 range. How long can I drive with my charging amps that low. It's still charging right? Just at a lower level?
n2ceptor
06-13-2004, 08:04 AM
AT the battery with the car idling, it should read 13.8 to 14.2 volts.. looks like your car is just running on the battery.... Battery voltage, alone, is around 12 to 13 volts if its holding a good charge...
