SMOKINGV6
06-12-2004, 01:36 AM
I HAVE A 96 Z28 W 45K MI, 4 WHL DISC,THE BRAKE PEDAL SEEMS SOMEWHAT HARD, DOES NOT STOP FAST ENOUGH IN PANIC SITUATIONS...(MY 87 G.N. STOPS QUICKER W/ STOCK BRAKES AND REAR DRUM) I'VE CHANGED TO CROSS DRILLED/ SLOTTED ROTORS IN FRONT W NEW PADS ALL AROUND AND EVEN REPLACED THE REAR END W/ A 99 TA REAR WHICH HAS THE LARGER ROTORS. THE DEALER CHECKED IT OUT AND AND SAID THERE ARE NO PROBLEMS. ..ANY IDEAS...OR SUGGESTIONS WOULD BE GREATLY APPRECIATED...RESPOND HERE OR EMAIL DIRECT TO SMOKINGV6@AOL.COM
THANK YOU
__________________
:confused:
THANK YOU
__________________
:confused:
