Anyone with this setup: Stock '95 Z28, 3.23 gears, rebuilt tranny with 2000 stall
warwickbass
06-11-2004, 08:24 PM
What are some 1/4 times you do?
MikeyG
06-12-2004, 05:22 PM
Sounds like a 13.8-13.9 car with a decent launch.
grumpy Z
06-15-2004, 02:59 PM
"94 w/same set-up. Best run 14.7. Would be better if I get better traction. This is way above sea level though. (NM)
Antz97ZNJ
06-16-2004, 09:37 PM
2000 stall is stock if im not mistaken or do u mean 3000??...so w/ stock setup w/ the 323's low 14's possible high 13's is a good guess....If you do have a 3000 stall first id suggest 373's but as it sits w/ a good hook you should be in the lower 13's somewhere
