blown383
06-09-2004, 09:20 PM
Can anyone help me read a datamaster file to find out whats going on with my car?
Some info on the car:
Okay .... Im able ready to push the car off of a
cliff...
I installed a CC 236/242 on a 110lsa, CC "R" lifters,
choromemoly pushrods, pro magnum 1.6 rockers, GM
guideplates, new valve seals, EX-612 valve springs,
CSI water pump, cloyes double roller timming chain,
and a new opti with new vaccum lines. Tuning was done
by Ion Sultan.
When I first cranked it over it fired up and ran fine
except for a slightly high idle. I drive around get
the debris out of the car so that I can change the
oil, however I left the low coolant sensor clip
slightly off and the lost about 3 gallons of coolant.
I reinstall the sensor and while burping the coolant
system I accidently ran the water pump on with the
t-stat housing off....so it drenched the opti.
I drive the car home and it sputters and isn't 100% so
I attribute this to the opti getting drenched. Changed
the oil, readjusted the rockers and discovered 2 were
off the valve stem completely. Fired up the car and it
ran good but with a stumble below 3.5K rpms. I pop the
hood and saw that all 4 primaries on the passenger
side where glowing red! Next day I readjusted the
rockers and cleaned the IAC valve.... fired her up and
now she won't idle.
I swap in a new IAC valve, readjusted the rockers one
more time...and same result. So Im thinking okay...its
the damn opti..I swap out the opti today with the old
one and it runs EXACTLY the same!!!!
Someone mentioned that I should try unplugging the MAP
or MAF sensor....same result....won't idle above
950rpms like it was programed to do...sputters then
dies. If I try bring the revs past 2K it stumbles and
misfires and pops. What the hell is going on?!?!
Big thanks to Mike Leaf who drove out to my house and
helped me diagnose the car. The guy stayed till 1am!
We're still having problems with the damn car, when
Mike scanned the car it had trouble codes indicating
problems with the MAF, MAP, O2s, and it also looks
like the long term log said that its been running lean
for a while. We ran the car till it went into open
loop to get some readings.
A mechanic friend of Mike's mentioned that it might be
the injectors thats causing the headers to glow, so we
swapped out the stockers for a set of SVO
30lbers....no change. So we decided to try and adjust
the rockers, Mike went with what looked like 1/8 of a
turn after zero lash and it idled a little bit better
but still sputtered and died. This time around BOTH
headers were glowing RED.
The 2nd time Mike scanned the car after the readings
the only thing that popped up was the MAP code, the
02s looked fine but I will replace those.
Mike has the files on his laptop, does anyone know how
or who might be able to interpret them? Im still
puzzled on whats causing the glowing headers and why
it won't hold idle. The IAC is new and showed counts
of 160.
-B
Mike's Input:
> Well, I guess I can interject here a bit and tell you
> all what I saw. First off, as Binhtri said, I used
> Freescan and Datamaster for the diagnosing portion, I
> then used tunercat to "re-tune" the computer to
> hopefully help even things out. As far as the plug
> went, it looked like it had been heated up a bit too
> much, but still looked more one the healthy side than
> anything. The MAP sensor did keep popping up in the
> trouble codes after we would run the car until it
> heated up enough and went to closed loop, so Im
> thinking that this may be a big culprit. I also
> noticed when running the car with Datamaster, that it
> was showing good spark advance, but was also showing
> an almost constant 8* of retard. I couldnt figure this
> out. If anyone out there is good at reading the
> datamaster files and figuring out possible problems, I
> will gladly e-mail his file to you. (Nick? Jason?)
> Anyways, Binhtri was a good host even though he worked
> me like a dog (j/k)
> he did treat me to In&Out, so I cant complain.
> Good Luck Bin!
> Mike Leaf
cliff...
by Ion Sultan.
now she won't idle.
of 160.
-B
Mike's Input:
> me like a dog (j/k)
> Good Luck Bin!
> Mike Leaf
