10.5" tires OK on 8" wheels?
97bowtie
09-22-2002, 05:53 PM
I am going to be purchasing some ET Streets in the near future (yes...finally going to make this pig hook :p). I will be going with a 26 x 10.50-16 tire. I plan on mounting them on salad shooters. I have seen 10.50s mounted on salad shooters in the past and I was curious if it is safe to run them on that narrow of a wheel. MT recommends the wheel width be +/- 1" of tread width, which would mean a 9.5" wheel. Any input/experience is appreciated. :)
Grover
09-22-2002, 06:07 PM
I have some 28"x10.5" ET Drags screwed to Weld Prostars that are 15"x8" and they seem to be working pretty good.
89ProchargedROC
09-22-2002, 07:12 PM
i'm running the same setup that a friend had and it worked great for him...
26x11.5x16 ET streets on a 16x8 wheel
rskrause
09-23-2002, 10:08 AM
Ditto.
Rich Krause
mongse_1
09-23-2002, 10:46 PM
Same here, only on a 15" dish.
94_Z28_ragtop
09-23-2002, 10:48 PM
I have 26 x 10.5 E/T Drags mounted on salad shooters and they seem to work just fine. I'm not using tubes either.
RichJ
09-23-2002, 11:10 PM
26x11.5s on salad shooters here too. They work great and look "right" too.
Rich
dougg01
09-24-2002, 10:15 AM
DOTs = measured at sidewall
Slicks = measured at tread
10.5 ET street is a DOT and the tread measures about 8.75". Out 11.5s measure about 9.125 across the tread.
Your mileage may vary. :D
Z97LT1
09-24-2002, 11:39 AM
How are you gonna keep that stock rear under the car? It's gonna complain loudly with those ET Streets.
97bowtie
09-24-2002, 07:18 PM
We shall see. ;) I know there are guys running ET streets on the stock 10-bolt. I understand it is a ticking time bomb...but I wouldn't be using them too often, so hopefully I will be OK. :) I am still contemplating the idea of drag radials, but I want the car to hook.
