oldschool 06-08-2004, 10:35 PM Well here is the story....
This past weekend I went on a houseboating trip and obviously did my best to break some traffic laws. The car was loaded up pretty good and I spent most of my driving in 6th gear...even the hills.
Anywho, the car started to get a bad vibration on the decel. So bad that if would vibrate the change in my console:mad:
I start driving to work today and I get BRUTAL vibrations in 6th gear @ part throttle, 1800-2000, 100km. The night before I didn't get anything really.
I made some calls and the guess was that it was the DS yoke because the way it was shaking the shifter (side to side). I changed it and the old one was dry but not ceased. There was also alot of oil under the car:confused:
As the story goes, the guy at the driveline place said that if that didn't fix it, it is probably the tranny.
A couple small things that I would think might effect it was that I got new tires last week. Maybe REALLY out of balance and wheel nuts loose? Probably would cause ythis much vibration:rolleyes: :cry:
Any Ideas?
Andy
TyphoonZR 06-08-2004, 10:49 PM Originally posted by oldschool
I made some calls and the guess was that it was the DS yoke because the way it was shaking the shifter (side to side). I changed it and the old one was dry but not ceased. There was also alot of oil under the car:confused: Any Ideas?
Ok, a couple of things.
1) do you mean that you changed the u-joint rather than the yoke?
2) did you check/change the u-joint at each end of the drive shaft?
3) did you check the oil level in the tranny? If you have an oil leak, that would be my first priority, next would be to fix the oil leak.
4) if a piece of the clutch disk let go, this too could cause a vibration, however it should be noticable even in neutral at 2000 rpm. (maybe not)
5) if the tranny was shot, then I would think that some vibration should happen in any gear at that certain speed at which you are travelling in sixth when this happens.
6) I believe that Dextron III ATF is the recommended fluid for that tranny, start with that.
97TA-WS6-Con 06-08-2004, 10:52 PM You have a custom DS or stock?
93formula 06-08-2004, 11:02 PM well i got a t56 for sale if you need one.
oldschool 06-08-2004, 11:23 PM 1)do you mean that you changed the u-joint rather than the yoke?
-We changed the joint in the back. We inspected the front joint and it was fine. There also was also a typical amount of play from the drive shaft where it enters the tranny
-no, the place I went to (GREAT PEOPLE btw!) where closing in 15 min, so all we had time for was the joint because that seemed like the logical place to start since it seemed pretty stiff
-no, there was just red tranny fluid leaking out when we pulled the DS and spread around underneith the car. It looked red which is encouraging...rather than silver.
-This would suck because I bought a Street Twin (used but very little KM) for big $$$:S The vibration is there at most rpms, but only really bad in 6th
-it is the stock DS with a 1350 joint. Apparently guys with 9-inches can get away with that...unlike with the 12-bolt.
-thanks Roy:)
StreamlineZ28 06-08-2004, 11:51 PM my car just recently started doing the same thing. vibrating on the decel. started right after a hard 1st-2nd shift but its only done it on 2 occasions. i had my 6th gear replaced along with all my synchros about 2 years ago. but that was because it got stuck in gear and wouldnt come out.:)
if your tranny was gone i dont think it would do it in just one gear and just on the decel. if it is on the decel id guess drivshaft u joints/yokes. or your 9 inch you raved so much about;) :)
95wagon 06-09-2004, 12:23 AM Put the car up on stands (under the axle tubes) and idle it in gear.
Take a good look at the driveshaft to see if it runs true.
Could the driveshaft have hit something?
Just a thought.
Gerry
93formula 06-09-2004, 12:45 AM did you check the tranny mount as well??
SBainsTA 06-09-2004, 12:52 AM Originally posted by 93formula
i was thinking the same thing lol
Draco 06-09-2004, 01:09 AM some guys with aftermarket rears (cough MOSER cough) run into problems when their driveshaft is too long and the front yoke bottoms out in the tranny... hopefully you have some play there for it slide back and forth like a **** in a ****.
Also, you beat on your car VERY hard when the geometry was bad - I hope this didnt upset the tranny. Now that I think about it, maybe the clunking was your driveshaft yoke bottoming out in the tranny when you were flooring it and getting wheelhop
TyphoonZR 06-09-2004, 01:46 AM Originally posted by Draco some guys with aftermarket rears (cough MOSER cough) run into problems when their driveshaft is too long and the front yoke bottoms out in the tranny...
Ok, I had no idea he was running a 9 inch and that there was a possible problem with driveshaft lengths. Definitely, if the shaft was to long, even if he got away with it for a short period of time, as time goes on and mounts begin to fatigue, at some point the driveshaft could easily bottom-out and cause ghosts to be heard.
Check it out with the jack stands under the rear diff housing in order to simulate road and load situations. Have someone add their own weight to the rear bumper and check to see if the shaft is coming into contact with the tail housing of the tranny. If so , well, you know what to do. Good luck, man!
97TA-WS6-Con 06-09-2004, 11:10 AM I had a DS problem although I think I got lucky and did not damage the tranny.
I took the stock DS to a shop and send, "Make me one the exact same length with 1350 yokes both ends."
They made the DS the same length, but the 1350 yoke is obviously bigger and longer thus the overall length ended up about 3/4 longer then the original.
I did not notice this when it was installed but it tore up the dust boot on the end of the tranny and pushed the tailshaft forward and destroyed the pilot bearing in the block.
It looks like I got lucky as that appears to have been the only damage. However, I did not notice any tranny problems at the time.
so you might want to check the DS length and make sure there is some play.
oldschool 06-09-2004, 09:29 PM I'm not sure if the length is the problem. The 12-bolt is the on you need to have a shorter length for as far as I know. I'm going to check the torque arm bolt to see if they are all there and tight.
93formula 06-09-2004, 09:48 PM the TA bolts are known to come loose or break off on these aftermarket rears. that would deffinatley cause some vibration.
OneFlyn95z28 06-09-2004, 10:43 PM BTW I know how to make a LS1 DS fit our cars with a 12 bolt or 9 in. Mail me if you want the info
oldschool 06-09-2004, 11:04 PM Just got out from under the car.
I jacked it up and left the weight on the suspension to simulate driving conditions. I ran it through all 6 gears and gave it part throttle in each.
I "think" (pretty sure) the noise is comming from the rear-end. It was kind of a rattle. What is weird is that from what I could tell, everything was spinning smoothly.:confused: When I put the clutch in the sound would go away, but I figure that is only because the load is off the gears.
any ideas?
Better yet, anyone experienced going to be roaming the North Shore anytime soon and want to do me a huge favour by listening to it??? :D :p
Andy
TyphoonZR 06-10-2004, 12:10 AM Originally posted by oldschool
Hey, I'm in for a roam....... do you have the tools and axle stands etc, so that we can play for an hour or so??? Let me know.
Draco 06-10-2004, 12:42 AM Originally posted by oldschool
any ideas?
Andy
Just a thought... you cant simlulate wheehop very easily with this method. The problem with wheelhop, acceleration, and the control arm angle I saw on your car is that as the wheels move up in the well, the rear end rotates up and forward around the mounting point of the control arm on the body. This rotation, which you cannot simulate easily with the rear end on jackstands, will push the Driveshaft further into the tranny.
good luck man, trannies are the most complicated mechanical system on the car and they scare me :(
oldschool 06-10-2004, 02:40 AM I am pretty sure it is the rear-end now Craig:cry: Either way it doesn't sound good.
Thanks Typhoon perhaps this weekend? I'll let ya know:)
Andy
sideways_Into_3rd 06-10-2004, 04:03 AM damn that would suck
wanna buy a reliable 12 bolt ;) ?
Hawk350 06-17-2004, 12:59 PM Check your plugs and wires. If your spark plug wires are burnt, the cylinders will misfire, and you may not even know. This will cause this....because it happened to me this weekend. Shifter was violently vibrating in 6th. Changed plugs and problem solved.
