3 wire, 2 bar MAP wiring
96 WS6
06-08-2004, 08:22 PM
I am using a 2 bar MAP for my alky injection. I know the green wire is the output voltage 0-5v. The other two wires are power and ground correct? Do I just hook up to a 12v positive and a ground? Simple answer, thanks!
Lonnie Pavtis
06-08-2004, 09:09 PM
You need 5VDC to power the sensor. You can reference it from the stock PCM or buy a power supply fromAlkycontrol (http://www.alkycontrol.com)
96 WS6
06-09-2004, 04:42 AM
So it has a 5 vdc reference signal and the black wire is ground then correct?
To get 5 vdc I can tap the power going to the stock MAP sensor correct?
RealQuick
06-09-2004, 10:52 AM
Omar, I am using the kit from you and would like to know as well. Is there a reason we cant tap into our 1 bar stock map?
94Z286SPEED
06-09-2004, 06:38 PM
just piggyback into the stock sensor center is used for reference signal that's it. you cant use the factory sensor because it will not see pressure when it hits 0 vacumm the sensor is maxed as the 2 bar sees up to approx 15lbs before it is maxed.
