Weird ringing noise!
Old Jun 8, 2004 | 02:27 PM
Articblast's Avatar
At idle you can hear a ringing from under the hood. Give it a little gas and it gets louder. I have the Rumbler cat back so I can't hear it while cruising. Any ideas? Idler pulley and belts were changed 2 years ago.
Old Jun 8, 2004 | 08:44 PM
`99 Super Sport's Avatar
Sometimes a rock or bolt stuck in between the header tubes at the collector will do that.
Old Jun 9, 2004 | 11:15 PM
mtorrez1's Avatar
its your AIR pump
Old Jun 10, 2004 | 11:49 AM
n2ceptor's Avatar
tensioner pulley bearing?????
a/c compressor????
power steering pump????
Old Jun 10, 2004 | 01:59 PM
The AIR pump should go off after the car warms up. Plus that's a humm more than a ring. I've heard of people with some problems with the AIR tube check valve when using headers, but I don't know what it sounds like...
Old Jun 10, 2004 | 04:01 PM
TraceZ's Avatar
a/c compressor????
Remove the belt and start the engine. See if that eliminates it, and work from there.
Old Jun 11, 2004 | 10:54 AM
Articblast's Avatar
Definetly not the air pump, this is a ringing noise instead of the hum. Thanks!
Nayr
Mar 3, 2023 08:34 PM
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
autoxr166
Sep 25, 2015 04:21 PM
mmf_1013
Sep 12, 2015 08:56 PM
