Blew engine, What would be a good 383 set up for 8psi?
xtremetrans
06-07-2004, 10:10 PM
I have an 8 psi pro charger with 42# injectors. What cam should I use, cc305? Any thing I should look out for. and who has the best price on a stoker kit? I think I am going to go with about 9:1 compression.
Mystic95Z
06-07-2004, 10:38 PM
A cc305 is not an ideal blower cam. Unless you already have it and dont want to spend the $$$ on a different one, I'd definatly spend the money on a custom grind blower cam. Can the Pro Charger you have make more than 8psi? With a 9:1 motor you'd be able to crank the boost up a bit more than 8psi safely.
-Tony
LukeZ28
check out
http://gofaststuff.com/index.html
they also sell parts on ebay
http://www.cmotorsports.com
RealQuick
06-08-2004, 01:09 PM
If you need to pass emissions, a few prominet board members here recommend a custom grind 214/224 114 LSA .565/.605 lift (#'s are w/1.6rr's.)
xtremetrans
06-09-2004, 09:16 PM
Do I have to do anything to the harmonic balancer? I was also thiking of gettig an aftermarket balancer.
