Muskys SS 06-07-2004, 02:45 AM Started the car up today and insured it. Finished off all the engine work and everything is picture perfect. I drove around a bit tonight with open Y-pipe, cause I'm still welding up the 4 inch Mufflex. All the new mods are:
Ported Polished Heads w/ 3angle valvegrind
Ported intake Manifold
Ported 52mm Throttle body
K&N FIPK
30# SVO Injectors
Vortech polished air elbow
Polished Aluminum Valve covers
Crane 1.6 roller rockers
LT4 hotcam
LT4 hotcam valvesprings
hardened pushrods
Lifters
Spec Stage III Clutch
4inch Mufflex exhaust
Accel 300+ Race Ignition
I've been taking it easy to break in the new clutch and the valve guide liners so I'm not sure how she goes. I hammered it once in 1st and 2nd gear and couldn't get traction, so that's a good sign;) All that's left know is to install the exhaust and give her a bath:)
93formula 06-07-2004, 02:48 AM sounds good man, if its stage 2 heads you got you should hit 355-365rwhp
JD30thZ28 06-07-2004, 02:48 AM Time to hi the track and dyno to get some numbers :) Street legals this fri :)
Muskys SS 06-07-2004, 02:51 AM Originally posted by JD30thZ28
I gotta put in enough km's to break in the clutch this week. If I do, I'm there!!!!!!!!!!!!!:cool: The car probably won't be tuned though....
BennyBoy 06-07-2004, 02:58 AM Nice! :D
Glad to see you got that 300+ installed. Any problems with it?
Muskys SS 06-07-2004, 02:59 AM Originally posted by BennyBoy
Nice! :D
Nope. Runs Great:)
Tw!tchb!tch 06-07-2004, 12:58 PM Sounds like an awsome combo :bow:
How do you like the spec ??
Camaro ChriSS 06-07-2004, 01:21 PM Ouch. Can't wait to hear it. Who did your heads?
Did you do most of the work youself? Cam install?
Drumhawk 06-07-2004, 01:40 PM Nice mods man. :bow:
Draco 06-07-2004, 01:51 PM nice man!
Let us know when you go to Mission, I want to be there for the maiden voyage.
Muskys SS 06-07-2004, 02:58 PM Originally posted by Draco
nice man!
I'm going to try and break everything in for this friday.
I did all the install myself and ported the heads myself. High Peformance Engines surfaced the heads and installed new liners and valve seals for me.
Muskys SS 06-07-2004, 03:00 PM Originally posted by Tw!tchb!tch
It seems to grab nice, but I do get some chatter if I let it out slow in low rpm's.
sideways_Into_3rd 06-07-2004, 03:07 PM when are u goin on the dyno ?
I dont have a cable anymore since i burnt mine tryin to help andy .. or else id help you out with the tune
Muskys SS 06-07-2004, 08:20 PM Originally posted by sideways_Into_3rd
I'm not sure??? I'm going to tune the car on the street with a wideband O2 then I'll take it to the dyno.
StreamlineZ28 06-08-2004, 01:00 AM Originally posted by Muskys SS
from what i have been reading that is normal for the specs and the Mcloed. mine does the same thing.
setup sounds nice. like to see the numbers at the track :)
SBainsTA 06-08-2004, 03:53 AM Originally posted by Muskys SS
it only does it for a while ~1500 km or so. a Couple of brake stands and it goes away:D the chatter in reverse is worse, havent got rid of that yet:(
sideways_Into_3rd 06-08-2004, 04:10 AM my street twin lost all chatter in all gears after 2 days of normal driving :D
if i have money when im doing a clutch, I will definitely grab another street twin :bow:
Draco 06-08-2004, 11:20 AM I'm going to try a Spec Stg III in the vette. Spposeduly they have a new disk called the X-pad which reduces chatter after breakin and grips upto 600 rwtq.
StreamlineZ28 06-08-2004, 02:40 PM mine doesnt chatter in normal driving just in traffic when the rpms are low trying to start. but mine like SBains is the sh!ts in reverse.
Muskys SS 06-08-2004, 07:58 PM Originally posted by SBainsTA
Yeah, reverse sucks. Feels like something is going to break. That's the beauty of a torque-arm:rolleyes:
o-zone 06-09-2004, 05:44 AM Sounds like a great set up Shaun, maybe I'll see
you cruising around in langley.
Cheers...
Muskys SS 06-09-2004, 09:25 AM Originally posted by o-zone
Cheers...
Yeah I'm always cruising around the walnut grove/ port kells area. Your car isn't green by any chance is it? If so that must of been your car I saw in port kells on monday
