tie rod help
Old Jun 5, 2004 | 03:07 PM
1.8ttolt1's Avatar
tie rod help
i am taking off the outter tie rod... to remove it are you suppose to turn it clockwise or counter-clockwise because I can't get the thing to budge one iota.
Old Jun 5, 2004 | 06:02 PM
carlos64030's Avatar
Counter clockwise. You do have the cotter pins removed right?
Old Jun 5, 2004 | 06:04 PM
1.8ttolt1's Avatar
its not the nut, its the actual outer tie rod i can't get to move, without my crescent wrench slipping off the inner tie rod.
Old Jun 5, 2004 | 06:59 PM
1.8ttolt1's Avatar
no one else eh, I guess its goodnight then.
Old Jun 6, 2004 | 12:23 AM
Spray some penetrating oil on the threaded area of the tie rod and let it soak in for awhile. You did loosen the lock nut before trying to remove the tie rod 1st right? And yes...you turn the tie rod counter clockwise to remove it.
HibachiZ28
Nov 6, 2015 12:53 AM
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
