Halfway done removing my antenna
Old Jun 5, 2004 | 01:59 PM
firebirdjosh's Avatar
I am removing the antenna from my third gen but I cut off the plastic and nut where it mounts, but now there is the long stem rattling around. How do I remove it, take off the fender?
Old Jun 5, 2004 | 11:52 PM
jeff94z28's Avatar
I just shaved mine a few weeks ago.
Old Jun 6, 2004 | 12:21 AM
So could you help me?
Old Jun 7, 2004 | 01:02 AM
Spinner's Avatar
The stem should be on the inside of the car mounted to the inside of the fender. Easily accessible through the rear plastic panel
Old Jun 7, 2004 | 12:04 PM
THanks alot!
Old Jun 7, 2004 | 02:17 PM
kgkern01's Avatar
When shaving the antenna, what is available to keep a good radio signal? I may end up shaving mine when it goes to the shop.
Old Jun 7, 2004 | 02:30 PM
AW/whiteZ-28's Avatar
Powered hidden antenna
Like this but cheaper
http://www.autoloc.com/detail.lasso?itemid=hab
You can get them for like half the price of that if you search around
Old Jun 8, 2004 | 10:22 AM
Dark Angel's Avatar
I ended up using the factory antenna. Drilled out the rivets on the mounting base and put it under the carpetalong where the hatch cover.
Old Jun 8, 2004 | 02:21 PM
kgkern01's Avatar
I can't really run the factory antenna, I have the power antenna unit - TA. I may end up going with the hidden antenna kit though. I have to have the rear pass side quarter blended anyway, so I might as well go ahead and shave the antenna while I'm at it.
marlar98
Sep 19, 2015 07:53 AM
Bxlt1
Sep 10, 2015 08:16 AM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
Bxlt1
Jul 18, 2015 02:48 PM
