DarkHorse
06-05-2004, 12:13 PM
What are the proper tables in which you change your shift points at?
I logged my runs last night with Datamaster and it is showing shift points of 6375 roughly. I'm trying to get the car to shift at 6000 but it keeps banging the rev limiter and will not shift at 6k on the 1-2 or 2-3 shift.
Do I have the dreaded high stall shift problem that is common in OBD1 cars and if so does anyone have the fix other than Brian Herter?
Anyone out there have 6k shift points that they can send me?
Also, i've noticed that TC changes shift points based on MPH, is there a way to changed them using RPM instead? I have the 1-2 shift set at 40mph right now and it seems ok after tweaking but the 2-3 shift I have set at 75 yet Datamaster shows it shifting at 84.
Help.
Help.
