bryanz882
06-04-2004, 11:13 AM
I recently purchased the custom amp rack that you put up against the rear of car from subthump link to rack here (http://www.subthump.com/acamarorack.htm)
I went online to look at subthump's directions for installing this thing, but if I wanted to access a rear light blowing out, it would make it pretty difficult. I was wondering if anyone who has this, came up with a way to install the rack so that it can be easily removed and installed. Ive been hurting my brain trying to come up with a clean secure way of installing this thing and I really believe it can be done.
For instance, I was thinking of putting a bolt going from the inside of the small 2X2 pieces of wood and coming out through the front of the amp rack, and tightening the rack to the bolt with a wingnut. But then i realized the bolt will probably spin when tightening the wingnut. Also the main support comes from the 4x4 block you place in the middle and thats on an angle, so thats another problem.
