How do you know when your going into boost ?
bowtiepwr
06-04-2004, 05:35 AM
>I have a vaccuum / boost gauge from Autometer and it seems to just register the vaccuum and not the boost . The car sems really strong , but I was wondering if it was just all motor . I plan to remove the S/C belt and try it that way to see if it is any different .
97WS6SCharged
06-04-2004, 05:39 AM
The boost needle goes one way, and the gas needle goes the other. :lol:
SMOKNZ
06-04-2004, 05:54 AM
First make sure your boost gauge is plumbed into the intake manifold. Then you find a nice long peice of open road and you pin the throttle to the ground. If there are no leaks in the line from the manifold to the gauge there should be some boost especially in the higher RPMs. That is if your belt is not slipping and all the intake plumbing is on tight.
MEAN LT1
06-04-2004, 08:26 AM
Heh.....you feel the "hand of god" start to push the car more and more as the rpms increase. Its a pretty cool feeling.:)
IDOXLR8
06-04-2004, 09:02 AM
LMAO :D
camarossguy2
06-04-2004, 09:16 AM
Try this...pump air or even blow air into the boost gauge tube...see if it goes up, just with my lungs i can move the gauge to like 2 or 3 psi... Its unlikely that the gauge is bad tho....Where do you have in plugged? make sure its not an opti line, those sometimes have one way valves on them
IDOXLR8
06-04-2004, 10:14 AM
Also when your car is off. What does your boost gauge read? It should be 0 if not your gauge is not calibrated properly.
1st and goal
06-04-2004, 12:12 PM
You've got to be kidding me:rolleyes:
There is a big difference between "really strong" and "smack you in the a$$"
aka - Really strong - all motor
Smack you in the a$$ - BOOST :D
I ran my Z for a while last fall as I got tired of throwing belts and it went "OK" but you should be sporting a chubba if you get into boost :)
Do you hear a whistling noise?
Are you running a fast system or modified PCM?
Who's doing your tuning?
Are you going to Camaro day at New England Dragway tomorrow?
If so I'l go for a spin and evaluate boost / no boost ;)
Marc
P.S. Like the "hand of God" comment ;)
bowtiepwr
06-04-2004, 03:09 PM
>cool :thumb:
I read the boost / vaccuum gauge at idle and it indicated 19" of vaccuum and it never indicated positive psi (boost) , but when the engine is turned off the gauge indicates 0 .
I plan to remove the S/C belt to see how it drives , and of course reinstall it .
SMOKNZ
06-04-2004, 06:46 PM
It's not going to read boost at idle :D
texlurch
06-04-2004, 07:59 PM
I have a digital one that reads vacuum and boost, it never does anything to let you know what it is reading, but I usually know when the boost comes on since that is also when countersteer is required! :D
It will read like 6 or 7 when just putting around, then start to drop when you get on it, but then start counting back up pretty quick.
bowtiepwr
06-05-2004, 04:57 AM
>thanks :bow:
