LT1RX7 06-04-2004, 12:04 AM Did know where to post this but I would think most people on this forum would know more about pumps.
They say the 8F001-550 billet pump from Paxton is suppose to be the exact same as the Aeromotive A1000 besides the casing. My brother has the A1000 and is loud as hell. Mine is so quite I have to click the key off and back on to make sure the pump is working
I have that exact pump and I have a step down box that drops the voltage so I can hear myself think when I'm putting down the street. Mine is loud as hell when I step it up to full voltage. I also don't have much of an interior in the car either.. but it would still be loud with full interior/insulation.
I would hook up a fuel pressure gauge (if you already don't have one) and see if the pressure ever falls.. if it does, maybe something is wrong with the pump.
Jeff 96 SS 06-04-2004, 07:19 AM I have had both pumps and it is a Aeromotive pump painted blue with a paxton label and it is loud! I would throw a MultiMeter on the pump leads and check the voltage. I can't imagine a quiet pump of this style wow are you sure its working, it should be very loud during the first couple seconds you turn on the key during the inrush start up.
Jeff
96 SS BLOWN
96 TA 396 D1
LT1RX7 06-04-2004, 10:20 AM I hooked it up strait to the battery and it still is quite. I know I'm getting fuel pressure cause the car starts up. Do you think maybe the fuel pressure is too low, I haven't check pressure for this car yet
Jeff 96 SS 06-04-2004, 12:23 PM I would still check the voltage at the pump with the car running and the pressure try to bump the pressure way up and see if it makes any noise. I don't know man it should make noise I have never seen one that wasn't loud as hell just last year replaced my bad one and it was loud as hell brand new.
Jeff
96 SS BLOWN
96 TA 396 D1
EDS Z28 06-05-2004, 11:30 PM Make sure you have the correct fuel filter and measure the current the fuel pump is drawing from the battery. A restrictive fuel filter will make the pump very loud. No filter will make it very quiet but you are taking a chance with larger particles damaging the pump. :)
LT1RX7 06-18-2004, 12:18 PM I just got off the phone with Paxton and they assured me that there pumps are not the same as Aeromotive A1000. They said there pumps used to be loud but have changed and now is alot quiter. Do you think I should trust them?
bkrepindy 06-18-2004, 02:42 PM Originally posted by LT1RX7
You should call Aeromotive and see if they say they are different. They will tell you if they build them for Paxton. Odds are you wil find out that Aeromotive does make it for Paxton.
speedmiser 06-18-2004, 02:57 PM hmmm... my A1000 is not too loud at all. Neither is the one on Texlurch's car. You can't hear the pumps when the cars are running...
96TurboTA 06-18-2004, 04:36 PM Have you checked your AFR with a wideband yet? I wonder if the quiet pump has anything to do with your extra heat in your headers.
LT1RX7 06-18-2004, 08:56 PM Originally posted by 96TurboTA
huh?? Even when the car is not on the pump is quite
speedmiser, my brother has the A1000 and it is freakin louder than s**t!!
Jeff 96 SS 06-18-2004, 09:39 PM I have owned both pumps. The paxton looks exactly the same, has the same dimensions and has the same specs HMMMM do not trust paxton tech-support on this one you would probably get a different answer if you called back anyway. Granted some are louder than others but they all make noise. Something is wrong I would call them and tell them you would like to send this pump back to be tested and replaced if found bad. I would not risk melting my engine!
Just my2cents
Jeff
96 SS BLOWN
96 TA 396 D1
LT1RX7 06-18-2004, 09:59 PM the tech guy told me the older ones were the exact same as the A1000. The new ones they sell now are made in house. He told me it is not loud but can be heard from inside when keyed on. He also told me to put my car on a dyno and look at the afr's:confused: That would probably cost me as much as the pump itself:rolleyes: He actually put me on hold to ask another guy that builds these pumps. He confirmed and told me again, these pumps aren't loud.
I'm temped to just buy another paxton pump just to see if it sounds the same and have it for a spare
Jeff 96 SS 06-18-2004, 10:13 PM Ya thats a great idea put your car on the dyno go lean because of the bad pump and blow your engine pure geniuse!
A spare pump isn't a bad idea these pumps don't last that long if you do alot of street driving.
Jeff
96 SS BLOWN
96 TA 396 D1
EDS Z28 06-18-2004, 11:48 PM I've got a spare for sale. Perfect condition too. E-mail me por favor. :)
texlurch 06-19-2004, 01:41 AM If you are not sure about a pump, check the FP! Cheap and simple..
You can NOT tell how a pump is working by the noise it makes, sorry! ;)
If a pump is noisier or quieter, I would look at line restrictions either before or after the pump. The Paxton/A1000 have -10 inlets and outlets, so if you are squeezing it into a 3/8 line, it will probably make more noise! The return line size will also affect it.
My A1000 cannot be heard when the engine is running, even at idle, but keeps a steady 55 psi at WOT. They are rated to free flow around 70 psi...
LT1RX7 06-19-2004, 05:58 AM Originally posted by texlurch
It's not the fuel pressure I'm worried about, any cheap pump can pull 50psi. Only a good one can keep pressures at high rpms and boost. BTW, I have a gauge and it reads good at idle, who knows when I start to boost.
I'm not trying to judge a good pump or bad pump from the sound. I've been searching and people all over have been saying my pump is the exact same as the A1000. I've heard the A1000 pumps and they can be heard from probably 1/8 mile away:rolleyes: The one I have can barely be heard from inside the car. This would be awesome if the pump is working correctly and can hold pressure at higher hp levels. It's not like I want a loud pump or anything
My lines right now are -8an going to the rails and then -6an going back to the tank. Doesn't really matter cause size of the lines doesn't make the pump louder, it's the pressure it's holding.
The only other thing I can think of is that my brother's pump is mounted strait on the frame and mine has cushin between the pump and frame.
texlurch 06-19-2004, 08:39 AM When I say check the FP, I mean under load. Mine is 38-40 at idle, and around 52-55 at 12 psi on the boost gauge at 6000 rpm. It is controlled by a boost referenced regulator (1 to 1).
I also have -8 feed, and -6 return, as well as rubber under the feet. The only time I hear mine is when I turn the key to make sure it is running, before I crank the motor over. I also know that I have a true 12V at the pump, thru a relay in the trunk. I didn't like the small wire that comes out of the DFI box to run the pump, so that activates the relay.
I can pull the cap on my fuel cell when the car is running, and see a heavy stream pouring from the return fitting, so I know my system is flowing well.
From my experience with Holley blue pumps, I know better than to bolt it directly to the frame! Talk about loud! :eek:
