How much nitrous safe with supercharger
Old May 30, 2004 | 05:24 PM
john35thss's Avatar
Just thinking about adding nitrous to my 383 supercharged combo. I have a 383 with afr 210 race 224 236 solid roller sq with aftercooler that is now pulleyed for about 11 pounds ( 7.2" 3.33").
Car made 510 490 on splitfire dyno (import shop up here with new dyno) with old combo I made 50 horse less on Splitfires dyno than ARE's dyno with same combo.
What are limits before I have to run exotic fuel I don't mind using 104 unleaded but leaded fuels are not an option and with 10 pounds boost and nitrous how much timing should I pull.
It seems the bar moves higher each year.
John Carpico
Old May 30, 2004 | 09:45 PM
steelheart's Avatar
a 50 shot of nitrous would give you a nice gain and cool down the charge quite a bit, i would also take out some timing as well,
Old May 31, 2004 | 06:04 PM
john35thss's Avatar
Thanks for reply, I am hoping some of the guys running both power adders can give me some insight. Do you use same jetting as NA car how much timing should you pull.
I know from experience tryng somthing and talking about it are two different things
John Carpico
Hal Fisher
Sep 30, 2015 09:03 PM
HAWG
Sep 25, 2015 11:41 AM
95blkss
Sep 22, 2015 03:18 PM
rideordie
Sep 7, 2015 08:22 AM
