raiderman119
05-29-2004, 11:26 PM
I am wiring my new HU and i get done, and i can hear the sound, barely, with the volume all the way up. I think that my amp is not turning on (factory amp). How do I fix this?. i bought the sochee adaptor to run the amp. . which wire is the remote line going into the amp? and what one will make my antenna go up.
LS1 RULZ
05-30-2004, 09:06 AM
Why are you using an adapter to connect a factory HU to a factory amp?
The factory amp doesn't use a remote turn-on lead. It senses when there is an input voltage coming from the HU and turns on.
raiderman119
05-30-2004, 10:24 AM
sorry, it is a jvc Hu, not the factory one. i re checked the wiring and there is no sound at all now. the amp is cold, so i know that it is not on. I need to know how to get it on.
LS1 RULZ
05-30-2004, 11:36 AM
This is the best adapter for adding an after-market HU to the factory stereo in a '99 Firebird.
PAC OEM-1 (http://www.affsave.com/pac.htm)
It plugs directly into the factory harness so you don't have to cut and splice any of the factory wiring. You'll also need the ADD-GM21C cable harness to go with the OEM-1
