BigRedZ28
05-28-2004, 02:38 PM
Ok, my friend wants to install a cut out on his Formula. He's got a stock exhaust system and wants to know where to put it for best gains/sound or whatever. Also how involved is the install? do you NEED to weld? Thanks for any info.
teke184
05-28-2004, 03:00 PM
you probably will need to weld since stock pipe is 2.75" and the cutout is 3"
put it in the pocket just before the axle...it fits perfect
MysticTeal 95 V6
05-28-2004, 03:24 PM
That's the same spot I had mine installed. If you position it in that pocket correctly, you can access it by laying down beside the passenger side rear tire easily :)
Kryckter
05-29-2004, 04:27 PM
Another vote for putting it right before the pipe bends to go over the axle. I just had a custom exhaust shop make me one real quick. It is real nice access if you lay on the ground by the passenger side back tire.
And if you don't want to lay down there just buy an electric cutout.I like my dmh.Had a qtp..like my dmh better.:)
Black01_Z
05-30-2004, 09:33 PM
weld one in right after the y pipe goes from 2 to 1 1 pipe.
