Mike94ZLT1
05-26-2004, 10:59 PM
I just swapped from 3.42's to 4.10's. Nice SOTP gain, what did you guys actually see?
M6 guys, what did 4.10's do to your track times?Mike94ZLT1 05-26-2004, 10:59 PM I just swapped from 3.42's to 4.10's. Nice SOTP gain, what did you guys actually see? Flat_Tire_ 05-26-2004, 11:03 PM Haven't swapped myself, however have talked to someone who has them .. He has a tough time getting traction at the track on street nights and he's running out of 4th gear by the end of the 1/4 .. he told me he's actually considering going to 3.73's. Although I know if you can hookup, you can see really nice gains. GREGG 97Z 05-27-2004, 10:55 AM .2-.3 and 2-3mph. rncotton 05-27-2004, 11:51 AM .2 in the 1/4 mile and about 1.5 MPH gain in trap speed. I'm on street tires, and a 1.9 60' time is as low as I can get them. Traction is hard to find with the 4.11 on street tires. But, trapping at 108.xx, I'm still in 4th gear, hitting 6K as I trip the light. redzsmoked212 05-27-2004, 01:14 PM if your runing steet tires your gonna see mabye .2-.4 gains through on some dr's and youll get up to .6 gains. simple 05-27-2004, 11:12 PM running out of 4th gear at the end of the 1/4? never had that problem with 17" wheels and tires with the stock cam! and i also found it easier to get traction :shrugs: Kevin97ss 05-28-2004, 08:24 PM --------------------------------------------------------------- and i also found it easier to get traction :shrugs: --------------------------------------------------------------- I think your the first person I've seen here say that! I feel the same way. After installing the Moser w/4.11's traction loss was much easier to control and it makes sence. True steeper gears increase torque which will make the tire easier to spin but it also reduces wheel speed @ a given RPM which = less momentum. If the tire loses traction it will take less time to get it under control. Kevin | ||
