MikeStank 05-26-2004, 10:00 PM I painted some pieces silver, and also i did some LED lighting. I have aluminum guage overlays so i was experimenting with how to get a nice glow on them. The radio bezel was not really meant to turn out the way it did. I at first tried some of those LED spot lights you see in stores, after i thoguht it looked stupid i had some holes in the bezel so i decided to cut the entire grove out and i used a piece of glow tube cut in half to fill the gap, i have 6 LEDs behind that. I ground out maybe a 1/4 inch from the bezel to let the light shine down onto the overlay.
I know I'm going to get some people cry rice, but i like the way it turned out actually.
Pics http://www.mjsphotography.com/birdint/index.htm
Lt1 and Ls1 05-26-2004, 10:24 PM Love the interior
FRMUL8D 05-26-2004, 11:41 PM That looks really classy to me. I plan on doing some of the same pieces silver to liven up the interior of my car here in a few weeks. Did you prep those pieces at all or just spray paint them silver? Like the lights too by the way.
MikeStank 05-26-2004, 11:52 PM Thanks for the good comments.
I did prep the pieces by sanding. i had a few deep scratches so i started with 60 grit and worked my way up. it doesn't have to be perfectly smooth like when working with wood. I then primed some peices, you really don't need to, but the primer really shows where you may need to sand again, or it will help smooth out your sanding job. I put a few coats of silver on, i wet sanded some of them, once i had a nice smooth surface, i then cleared them till i didn't feel like spraying anymore. I had troubles with the guage bezel, i'm not completely happy with it, mostly because my clear coat can was spitting. I may have the stuff painted when my car gets painted though.
I'm going to do the hard plastic cover on teh center console soon, but i was waiting till i can afford a new shifter knob. Take your time and it will turn out good.
guitardedjf 05-27-2004, 11:08 AM very classy, nice job.
z28marine 05-27-2004, 12:19 PM where did you get the LEDs? and how hard was it to wire them in?
Red95M6Z28 05-27-2004, 12:49 PM Thats not rice. Trust me I have been in the Honda/Acura scene for years and I can spot rice from a blimp in a fog storm! That looks great! Your whole car is the shiznit!
Need4Camaro 05-27-2004, 04:42 PM If you believe thats Rice, then a Stock Honda is a Rice Crop! Thats FAR FAR FAR FAR FAR from rice!!! Nicely done man, you just put the ideas that I wanted to do for my car to shame!! I'd like to use silver too but I don't think that goes well with tan... Keep up the good work!
MikeStank 05-27-2004, 11:31 PM SVT03, i did not paint them, they are aluminum overlays from MBA. I removed the original 12v lights, and ran my LEDs right off the open circuit.
z28marine, i bought the LEDs from http://superbrightleds.com/
They are very simple to wire, if you only want one, you wire one 470 ohm resistor in series with the LED.
RS Dragster 05-27-2004, 11:58 PM Damn, I think that looks really nice man :cool:
Too bad you can't get the guages to glow blue to match everything else, because that's the only thing I see wrong.
coogsLS1 05-28-2004, 12:15 AM looks damn good! How long did it take you to paint those pieces? Might get around to doing that this weekend if Im lucky!!
I agree with RS Dragster, change out the LEDs behind your gauges
RS Dragster 05-28-2004, 12:19 AM Originally posted by coogsLS1
I don't know if it's as easy as LED's. I had my guages out once, I didn't see what was making it that color. It might just be white lights behind a orange/red lining. :confused:
MikeStank 05-28-2004, 12:24 AM yes there is a lining back there, not as simple as new bulbs. It can be done though, i'm probably going to get some reverse gloq guages though.
MikeStank 05-28-2004, 03:09 PM they cost to much, but now that they are illuminated a little i like them. I wish MBA would just cut out the lighted areas so we could make better use of them
coogsLS1 05-28-2004, 05:05 PM what was that illustration that was made by a member with the locations of the dash gauge lighting. He just switched out the LED lights and it changed the glow color. I could be wrong tho...
MikeStank 05-28-2004, 09:21 PM the camaros can be done like that, the firebirds have a red film over the backing which is not easy to remove
coogsLS1 05-28-2004, 11:01 PM I didnt know that, thanks for the info!!
Brent94Z 05-29-2004, 12:44 AM That looks great! I like it. A lot of times I don't like many interior mods like that but as has been mentioned previously, I think yours came out "classy" looking!
Did you change the lights in the doors that illuminate the locks and windows switches? What LED bulbs did you buy from that place?
-Derek
very nice by the way!
MikeStank 05-30-2004, 12:44 PM Yes, i pulled out the red bulb and its holder from behind the doors, and just widen the hole a little so the new LED would fit in. The bulbs i bought are the Part Number: RL5-B5515 Honestly, i think you can go with the weaker ones in the doors, I'm not going to change mine out now though
cbuns55 05-30-2004, 07:29 PM Did you just use regular old spray paint? If so, what brand of paint? I bought the Wal-Mart brand silver and clear, but i have yet to do it. Any other suggestions before I dive into painting?
Buffdaddy 05-30-2004, 11:04 PM I like the interior especially the blue lighting!
PDCamaro318 05-30-2004, 11:54 PM looks sharp....nice job
MikeStank 05-31-2004, 12:08 AM wow, i like all the good responses:bow:
Crazyjim, ithought about a differnt shade, but that is a CLOSE match to my exterior, but after seeing it with my aluminum overlays a darker shade would set them apart. When my car gets painted i'll decide then.
cbuns55, I used the plastikote stuff from pepboys. It worked well for me, except i had a can of clear that was spitting and i have a few dark tiny spots on my guage bezel. Some stress prepping more than anything, I do recomend sanding as it doesn't take much longer. Primer is not neccessary, but i again recomend it, it will at least show you how good your sanding job is before the base coat. only need to base coat it until it looks good, then spray clear till you dont' want to anymore. clear needs to be really light smooth coats if you want a nice smooth finish. Start with easy pieces like the radio bezel and the door trims, the bezel is the hardest to do because of the curves. Don't try to rush all the pieces in one day unless you have the room to lay everything out.
My finance already scratched one of my door pieces with her ring, so i'd strongly recommend fewer coats to keep it thin, although I think she would have scratched the unpainted surface with how hard she hit it:rolleyes: Sometimes I think about not allowing passengers in my car.
doombunnie 05-31-2004, 03:05 AM I like it a lot
stangkilla1 06-03-2004, 09:44 AM I see nothing rice about it!!!!
good job man. The factory lighting is so dim that you almost HAVE to upgrade to something different. You should check out "rhinosarehorny" car. He did something like that to his including his vents.
2Poor4Z 06-03-2004, 11:50 AM as far as the gauge lighting go.. the camaro have a blue film in all of their gauges, HAVC, and headligth control knob areas. I have replced all of my lights with white LEDS and it still has a sort of bluish tint to it. You cannot remove this film period. You can however do a gauge cluster swap out of a camaro into a TA if you want the Blue gauges. I have seen it done several times. The LEDS behind the gauges are size 194 bulbs and are just straight plug in
MikeStank 06-03-2004, 01:20 PM I was under the impression that they weren't an exact replacement, am i wrong
MikeStank 06-03-2004, 01:21 PM I have 5 feet of electro light tape here, i'm not sure what i want to do with it if anything. it was my original idea for adding some light to the aluminum.
)2overt SS 06-03-2004, 11:10 PM I don't see any rice :cool:
Awesome job :thumb:
Cmr0z28 06-04-2004, 12:27 AM Looks awesome man.....great work!
