sideways_Into_3rd
09-21-2002, 01:18 PM
heres my time slip
RT: .678
60': 1.842
1/8: 7.824
mph: 91.24
1/4: 12.101
mph: 115.71
and thats the best 60' i could get
my car is lowered, i have all the beefed up rear suspension parts/ SFCs .. i did NOT get a chance to weld in relocation brackets on my new rear end yet .. my car is an M6 / street twin / 3.73s strange 12 bolt (now broken after that run !? wtf ?!)
i removed the front sway bar .. yet the best 60' i could get was 1.84 ... i ran my 10.5 x 15 ET streets at 12 psi cold ... heated them up very good ... and popped my clutch at 5500 ... the video for that run should be up shortly ..
i think i was spinning them because that night i got 4 passes .. 3 of them with 1.87 1.85 and 1.84 60' times .. and i launched much hater progresively .. first was 3800 , then 4500 then 5500 ... so i guess i must've been spinning them
any ideas ? i really need another .2 to get in the 11s .. though i broked my rear end im not sure if its gonna happen this year anymore .. but who knows ... thanx
Fastbird93
09-21-2002, 03:42 PM
My guess would be that once you weld in some relocation brackets for the LCA's that you should be a lot better off.
Fred94LT1
09-21-2002, 06:55 PM
It sounds to me based on your 60' and a 5500 rpm "Dump the cluth" launch you must be spinning. I'd say the track prep wasn't as good as it could have been. You broke a 12 bolt on the last run right? In other words no time? That would have probably been the run it hooked on. 12.1@115 is awesome though. The "Only" thing keeping you out of the 11's is the 60'. I would definately make it my next project after repairing the 12 bolt adding the relocation brackets. When I flash my converter it launches at 3000 rpm's. Man I would really think hard before I launched my car at 5500 rpm's. It costs too much IMO,
Fred
sideways_Into_3rd
09-22-2002, 04:25 PM
videos are up ...
this ones me and the mustang with $13,000 engine built by rash paul and 175 shot on ET drags ... too bad he got spanked by a home made NA chev
http://www.members.shaw.ca/payam/payam-john.mov
this is my 12.1 run .. listen closely and u'll hear the rear end go boom and the 4th gear chirp i got
http://www.members.shaw.ca/bctfb/Payam12_1.mov
these vids are about 6 megs each and are MPEG 4 encoded .. which means u'll need quicktime 6 to view them
http://www.apple.com/quicktime/download/
RichJ
09-22-2002, 10:43 PM
Is it possible that your new rear wasn't broken in? I've heard that some times the gears can fail if they aren't heat cycled properly before racing. I dunno. A 12-bolt shouldn't break if you are spinning out of the hole. Do you know what broke?
Are the tires pretty new? Even a lowered car will generally hook up better than that with the MTs.
The relocation brackets should help. I just got mine installed and test drove it tonight. They make a noticeable difference on the street. My street tires feel more like drag radials now. I'm hoping that these brackets will help me get a 12.1 though at a lower MPH than you. This weekend I hope to go the track and find out.
I'm envious of your MPH. What cam are you running?
sideways_Into_3rd
09-23-2002, 12:02 AM
my rear end was new when i got it .. i put on at least 1500 miles of city driving / road trips before racing with it ...
i WAS spinning the ETs ... how did u launch ur car ? what rpm did u dump ur clutch at ??
I run the CC306 (230 / 244 - .544 / .576 112) .. not a good NA cam at all .. i want the XE236/244 ... but for my next setup im going with a solid roller and direct port N2O ... my heads also flow 293 / 224 @ .550 .... so that might have something to do with it ;)
my car also weighted in at 3520 that night and i dynoed 371
i dont know what i broke in the rear end ... i'll look at it in a while .. just bought a beater
RichJ
09-23-2002, 08:39 AM
When I launched mine, I also just jumped off the clutch. I didn't side step it, but I did lift my foot off all at once. I started at 4000 rpm...1.80 60-foot. Then 5000 rpm...1.71 60-foot... Then 5500 rpm...1.69 60-foot.
My car isn't lowered though.
What do you mean that the cc306 isn't a good NA cam? I thought that one was one of the best. Bad street manners but great top end. No?
sideways_Into_3rd
09-23-2002, 01:12 PM
I personally think CC306 would make a killer N2O cam .. specially if it was ground on a 114 lsa ... i'd rather have a 236 / 244 on an NA car ...
the top end is good yes .. my peak HP was at 6350 i think .. but thats when the dyno guy let off the gas .. (my stock fuel pump couldnt hold pressure / ran lean) .. i bet if i had enough fuel and moved the rev limiter i'd make peak power at 6500 - 6600ish .. and the street manners are horrible .. tuning helps .. but still :death:
