Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
What do you have left to do on the car before M7?
Old Sep 21, 2002 | 07:55 AM
Black Sunshine/ 00SS's Avatar
I know I've got a list, how about you guys/gals?
Old Sep 21, 2002 | 08:07 AM
99 1LE Hugger SS's Avatar
Ive got the rollbar in and painted, battery relocated to the hatch, subframe connectors in, torque arm is installed, aluminum fuel cell for the nitrous is done.
Now ive got the Hal struts and springs to install, and plumb the new fuel system for the bottle and im ready for some wheels up action.
Lookin to do some track testing soon.
Old Sep 21, 2002 | 08:28 AM
ur2slow's Avatar
Unhappy
Hopefully I will have the 4.10 installed if I can get a hold of somebody to do it before then. I've been trying to get a hold of 1bad86z, I hear he is the man for the job!
Old Sep 21, 2002 | 09:25 AM
derty's Avatar
New master cylinder, came home last night and saw a nice puddle of fluid on the floor, WTF!!! After that then it's time for some practice, practice, practice! I'll probably be out at Stanton Wednesday night for some TNT.
99 1LE Hugger SS, if you need some floorspace to get all that done let me know. I'm on vacation all week just screwing around with stuff at home.
Old Sep 21, 2002 | 10:20 AM
Grover's Avatar
I've got some more grinding to do on the brake calipers to get the slicks on and then I have to finish wiring up my launch RPM selector.
Old Sep 21, 2002 | 10:31 AM
one wicked element's Avatar
I need to get a new battery - as mine is slowly dying.
An aftermarket transmisson mount.
Get my 3.73s installed.
Get a Drive Shaft Loop.
.........and borrow a helmet from someone.
Milo.
Old Sep 21, 2002 | 05:38 PM
I'm still waiting for the TQ convertor to come back. I would like to change fuel and nitrous filters. Get a micro WOT switch hooked up for the nitrous. Drill out some extra jets a few thousanths
I'm sure there is more, but I'll start there.
Old Sep 21, 2002 | 05:43 PM
transamtom's Avatar
Unhappy
Ignition/spark problem,a header leak,my TQ converter and tranny cooler if they get here on time
Old Sep 21, 2002 | 05:44 PM
derty's Avatar
Just rebuilt the master cylinder, time for some test driving! Fricken sealing washer was ripped and spraying fluid out when you push the pedal down. Anyway, all set just cleaning up the car now.
Old Sep 22, 2002 | 12:12 AM
AutoRoc's Avatar
Honestly?
From front to back...here's the list
Rebuild entire steering system/tierods/idler
Alignment
Spohn Sway bars (36/24mm)w/endlinks
New wheel bearings
KVR crossdrilled rotors
KVR pads
possibly stainless lines
Jamex 1" drop springs
Koni Yellow shocks(front)
Oil change
Install new NX STage 6 nitrous plate and plumb it up
Make stage 6 plate fit under hood somehow
SLP headers
SLP Y-pipe
3" Flowmaster Delta Flow 40 series muffler with turndown
Install old 10 bolt with 3.73 gears, Auburn Pro
T/A Cover
Royal Purple fluids
Spohn Lower control arms
Spohn adjustable panhard rod
Spohn LCA relocation brackets
INSTALL WALBRO 340M fuel pump
Run new fuel pump wires(bigger!)
I may be missing a few things also...wish me luck. Luckily my buddy Joe is helping out bigtime!
Looking for a new best at M7!!!
Old Sep 22, 2002 | 12:26 AM
AL SS590 M6's Avatar
Moderator
Post
Well I have the Super Sucker installed and I need to test that on a better day than last Wed. was
The off road Y-pipe is on it's way. Hopefully it'll get here in time. And I need to swipe the O2 sims off from Rods car to take care of the Cats being gone.
Steve and Matt,
If the weather is good look for me at Stanton on Wed.
Old Sep 22, 2002 | 03:24 AM
Thanks for the invite derty hopefully i can get the struts on before wednsday so i can see if my new suspension can take the power. Last time i tried i spun my ET streets all the way through first and into second and still ran an 11.30@123.8 through the exhaust.
Al I hope to make it up to stanton on Wednsday or maybe even martin on friday( now that im legal )
Derty i seen you drive by at rogers tonight. You should stop by sometime. I didnt know it was you till you drove past and i seen the license plate. I had to leave not to long after that (after givin a few freinds some nitrous runs down 28th.)
2 weeks and counting
Old Sep 22, 2002 | 09:05 AM
derty's Avatar
We just drove through real quick on our way to the bar. Just a minor detour! I got the car all fixed, I hope nothing else decides to break. So at this point it looks like I'll have some TNT action this Wednesday.
Old Sep 22, 2002 | 02:36 PM
cASe SenSiTive's Avatar
Exposed Member
Gotta chase down an electric gremlin. It's either a short in the wire, or bad ground. Keeps blowing the engine-sensor fuse.
Then I gotta finish tuning it... Hmmmm... I wonder what it'll do when it's actually running good?
Old Sep 22, 2002 | 02:52 PM
CMYZ28's Avatar
Gotta get the rear end redone, as it's decided to crap out on me :-(
