Quick69
05-24-2004, 02:45 PM
with 20lbs in them and a 2k rpm launch its wheel hopping bad, should I go with less pressure. My best 60ft was with a soft launch an a 1.80
the car has mono leafs,cal tracs and comp engineering shocks
Quick69
05-24-2004, 02:46 PM
the tires are 275/60/15 Nitto DR's
AllGoNoShow
05-26-2004, 09:16 PM
I'd adjust the cal-tracs....there is no way you should be getting wheel hop with cal-tracs if they are adjusted right.
Just curious, I have the same tires, what rpm, gear, and how long do you do your burnouts for?
Quick69
05-26-2004, 09:19 PM
I've tried from a little hot to alot of hot with the same results:confused: :confused:
