brain
05-23-2004, 09:48 PM
I have a 94 Camaro, with the U82 speakers. There are no speakers behind the seats, only the doors and drivers rear sub. Here is the problem. I never had to buy the convertor box that my friend did for his 95 with Bose premium sound. I had best buy install a JVC stereo for me years ago. Since then, I had removed that deck, put in a Sony and it worked fine. Swapped that for a different sony, and it worked fine. That deck was stolen, and they took the harness that clips to the factory setup. I bought a new harness connector but CANNOT get sound to come through the front speakers. The rear works fine. I have had the front speakers replaced with aftermarket ones for years, with no trouble. Friends have told me I need to run new wires to them. Why now, but not before? What has changed? The guy that wired the deck originally doesn't work at BBY anymore, so I can't check with him. The new guys there are no help. Circuit is no help. Does ANYONE know how to wire it up to get the sound to come out of the front speakers?
Note: Sound comes out, but it is so low, you can barely hear it with the volume all the way up, on just the fronts. I have confirmed that there is power going to the door amp, the ground is good, etc.
ANYONE? I hate to pay best buy $50 to wire up the doors, if not needed. Thanks!
EDIT: Holy crap I think I found it. One of Brents old posts say you need to hook up the power antenna wire to switched 12V. If thats it Im gonna crap, cause I did everything BUT that!
