Black smoke caused by dead battery?
Old May 23, 2004 | 01:37 PM
Detroit808's Avatar
A week ago I posted about a stutter at low rpm's and rough idle that showed up in my 94Z. There was also black smoke coming from the tailpipes (rich or misfire?). I went on a trip for the last week, and now my battery is completely dead...not even the map lights/power locks work. So it came across my mind that, while I was thinking I need to change the plugs, wires, or opti...could my problem actually be the very weak battery? The stuttering/smoke appeared just a couple days after upgrading to a strereo with slightly more current draw. In any case, I'm changing the battery first, but I'd like to know what you think.
Old May 23, 2004 | 06:44 PM
Lyle A's Avatar
A weak power supply can cause sensor malfunction. So, it could make your car run abnormally. See what codes it may have stored. This thread should be in LT1 Tech.
liamcg97
Nov 25, 2019 05:55 PM
robcarnut
Mar 20, 2015 03:40 PM
captcorvette
Mar 7, 2015 12:37 PM
dale3in98
Feb 14, 2015 12:18 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
