tune port fuel rails needed
Hot Rod Hawk
05-20-2004, 09:09 PM
friend crossing over too efi and the stelthram. It will work with the stockers tune port fuel rails just fine. Who has um lay'n around hes got cash in hand and a itchie trigger finger on the buy now button.
Hot Rod Hawk
05-21-2004, 10:19 AM
come on someone here has to have these lay'n around ;)
ws6transam
05-21-2004, 03:39 PM
I have a set, including pressure regulator. They are from an '87 IROC, I believe. I also have the Earl's -AN fuel line adaptors for this fuel rail set so that it can be retrofitted into cars without OEM TPI fuel lines.
Big Blue Brick
05-21-2004, 03:44 PM
how much do you want for them?
Hot Rod Hawk
05-21-2004, 04:13 PM
Dan, kool!!
bigbluebrick ...bill is who needs them. You meet him down in Memphis, he was with me and TAjack on the trip.
ws6transam
05-22-2004, 10:54 AM
$75 should do it, including the customized adjustable fuel pressure regulator and Earl's -AN fuel line adapters.
RedIrocZ-28
05-23-2004, 10:05 PM
Hate to rain on the parade but stock TPI fuel rails will absolutely not fit on a stealth ram. I tried... but they're simply too short.
ws6transam
05-23-2004, 10:51 PM
RedIROC, that's good info.
However, what injector rail does the StealthRam use?
I'd like to know for sure, purely out of curiosity.
Big Blue, if you want to try them out and give them back if they dont fit, that would be okay too. Better yet, bring over the manifold one of these days to my place and we'll test fit.
Got injectors?
RedIrocZ-28
05-24-2004, 10:06 AM
The Stealth Ram either has a set of fuel rails you can get with it or you can make your own with aluminum fuel rail stock. The Stocker TPI rails wont even fit over the very top of the "stacks" when you have the plenum off. They're too narrow, and would NEVER clear the bottom where the stacks flare out. I only cal them stacks because I dont know what they are called. I could take pictures in the next few days but I'd have to get over to my car. Also, I believe the injectors are in the wrong place on the stealth Ram compared to the TPI. The wiring is long enough to compensate though.
Check my sig for pictures, don't mind the rest of the pictures.
