gamecockfan04
05-20-2004, 04:46 PM
OK, I bought a Commando Keyless Entry system over a year ago and have still yet to figure out how to hook it up. Can someone please help me, or would it be easier to find a transmitter from a 94'-95' TA and use the factory system? Would the factory system plug right up, or would it require, some configuring?
Javelin3o4
05-21-2004, 02:50 AM
the 95 bird has a 5 wire locking system, check www.12volt.com for how to wire up the relays. Here are the notes directed supplies when hooking up the relays though.
on-keyless versions: Use light blue for lock and dark blue for unlock. Both wires are located in either door harness. The passenger switch is the master switch. Keyless versions: Use red/black for lock and orange/black for unlock. Both wires are located in the passengers kick panel at the keyless entry module. Do NOT use the orange power wire at the keyless module or door lock switch to power your door lock relays. The passenger switch is the master switch.
gamecockfan04
05-21-2004, 08:50 AM
What exactly do I need to click on on that link to see what I need to see.
Thanks for the Reply,
Brent94Z
05-21-2004, 08:56 PM
You can also download the zip file on this page for the 93 to 95 F-Body. Should have the info in there you need!
http://www.bfranker.badz28.com/fbody/alarm.htm
