housh
09-20-2002, 06:35 PM
WTF? I know there is info here about an electric cut out install. I have searched and nothing. can someone point me in the right direction??:( :( :(
electric cut outhoush 09-20-2002, 06:35 PM WTF? I know there is info here about an electric cut out install. I have searched and nothing. can someone point me in the right direction??:( :( :( 2001NBMZ28 09-20-2002, 07:21 PM What do you need? Routing the wires, power connections, ...I installed my QTP electric cut out a couple weeks ago. housh 09-20-2002, 07:32 PM I am wondering where to route the wire. I hear there is a hole near the right rear seat? If so how do I Identify the hole. I imagine I would have to pull the carpet up then into the center console? Thanks, Jeffrey:confused: 2001NBMZ28 09-20-2002, 07:40 PM There's a rubber drain plug in the bottom of the seat pan. I cut an "X" and inserted the wire there. One bolt removes the bottom cushion. Then route the wire under the console (just loosen the 4 bolts and tuck it under). I used the black wire from the cig lighter for ground, then ran an extended wire under the dash to the 15 amp radio fuse inside the car. I bought a convertible bezel switch from my dealer and mounted the switch there. Hope this helps. | ||
