whiteslpz
05-19-2004, 06:41 PM
I'm going to get 4.11 gears, where did you guys get them from.
Jason
Jason
4.11 gear ?whiteslpz 05-19-2004, 06:41 PM I'm going to get 4.11 gears, where did you guys get them from. Jason importeater 05-20-2004, 09:04 AM I got mine from Drivetrain Specialist 1-800-216-1632. They are Sierra Gear. Ask them to go back an count the teeth because all there brands are marked 4.10-4.11.. some are 4.10 some are 4.11, you want 37 ring 9 pinion. Sometimes Motive gears are 4.10's sometimes 4.11's depends on where they were made. I dont have any problems with mine, they wine a little like Richmonds but not bad, I also had mine installed a little tighter since its not a daily driver and I wanted a little stronger for the track. Craig rncotton 05-20-2004, 09:41 AM I got a set of Motive 4.11 gears from a local shop for $150. If I recall correctly, if you get Motive gears, the ones made in USA are 4.10, and the ones made in Italy are 4.11. unvc92camarors 05-20-2004, 09:58 AM what's the difference between 4:10's and 4:11's? i tried a search and didn't come up with anything so... 1984camaroz28 05-20-2004, 02:01 PM Originally posted by rncotton I got a set of Motive 4.11 gears from a local shop for $150. If I recall correctly, if you get Motive gears, the ones made in USA are 4.10, and the ones made in Italy are 4.11. yea i also got mine from a local vendor and me an my dad put them in 1984camaroz28 05-20-2004, 02:03 PM Originally posted by unvc92camarors what's the difference between 4:10's and 4:11's? i tried a search and didn't come up with anything so... the .01 I was red something a few weaks ago the 4.11 are stronger becuase of less teath but who no's Capn Pete 05-20-2004, 03:29 PM Originally posted by unvc92camarors what's the difference between 4:10's and 4:11's? i tried a search and didn't come up with anything so... "importeater" helped answer that;). It has to do with the number of teeth on the gears. 4.10's are very typical GM gears, using 41 teeth on the ring gear, and 10 on the pinion gear (hence 41 / 10 = 4.10 :thumb: ). Other common ratios such as 2.73, 3.42, and 3.73 also use 41 teeth on the ring, with varying # of teeth on the pinion. 4.11's have 37 teeth on the ring gear, and 9 on the pinion (37 / 9 = 4.11) but having less teeth on the same "size" of a gear, makes the teeth thicker and therefore stronger;). importeater 05-20-2004, 03:30 PM Originally posted by unvc92camarors what's the difference between 4:10's and 4:11's? i tried a search and didn't come up with anything so... Look here, http://www.geocities.com/greasemunkeey/411vs4101.jpg, you tell me ;) There is a big difference believe it or not 4.10's = 41 ring teeth 10 pinion 4.11's = 37 teeth 9 pinion.. less teeth in the same amount of area = bigger teeth = stronger teeth. Craig EDIT: Click and drag the link to the address bar.. Capn Pete, you read my mind, just about word for word :bow: Somnambulist 05-20-2004, 09:27 PM 4.11 gears are also supposed to have less "whine" than a higher ratio gear... kgkern01 05-23-2004, 05:55 PM I have heard from a guy who installs a lot of F-body gears that the 4.11's whine more than 4.10's do, and he doesnt recommend them due to this fact. Is this true? Somnambulist 05-23-2004, 05:58 PM no Pony Punisher II 05-23-2004, 06:31 PM GM 4.10's are the best to go with. 41:10 teeth, and they NEVER whine. I've installed 100's of these with no problems. whiteslpz: sent you a PM -Jason unvc92camarors 05-24-2004, 06:45 PM thanks guys for answering my question i guess i'll go with 4:11's if i decide to on my z (getting it this week:D :cool:) o, and i would've posted earlier but my comp has been f***ed up this week:o | ||
